I have Manjoro gnome version dual boot with windows 11. Wifi wasn’t working so I ran
sudo sed -i ‘s/3/2’ /etc/NetworkManger/conf.d/default-wifi-powersave-on.conf
Now the wifi button is gone on linux and windows and I dont know what to do
You changed some value in that file (presumably)
Undo that change.
Why did you not use some visual editor to alter that file?
What do the contents of that file look like now?
cat /etc/NetworkManger/conf.d/default-wifi-powersave-on.conf
mine is:
[connection]
wifi.powersave = 3
and it works that way and always has
You set it to “2” instead of “3” - revert that if you think that that was the reason for your problem.
What was the reasoning behind that change?
(possible XY problem)
Edit the file. The content should be like this:
[connection]
wifi.powersave = 2
You can also run nmtui from Terminal to edit or activate the connection.
This might suggest you have inadvertantly broken your wifi fuctionality. Configuration made in Linux typically has no effect on Windows, however, the reverse is possible, if Windows Fast Startup happens to be enabled, for example.
If you expect help with this issue, more information may be needed. Please provide your system information as described (below) to allow others to help further.
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
It is important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem. Please also be prepared to provide output from commands if/when asked.
Simply waiting for others to ask you questions is counter-productive – typically, nobody has a
at their disposal – and your clear, concise and accurate input is often relied upon in order to help you.
Please help others to make informed suggestions based on information you provide.
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly; ![]()
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
inxi man pages |
(manual) |
--color=0 to the long-form command, or…inxi -zv8c0
