Hi!
After last update a cannot connect to secured wifi networks.
The only way to connect is disable WPA on a router and make network unencrypted.
In dmsg I found errors about 4-way handshake timeout.
After few days of research I solved the problem by downgrading wpa_supplicant package from 2.10 to 2.9 version.
Any ideas how can I help to investigate the problem with 2.10 update?
My network adapter:
inxi -Nxxxa
Device-1: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel
bus-ID: 02:00.0 chip-ID: 8086:088e class-ID: 0280
I am using 5.15.19 kernel
