Need to Updated 700 packages after removing Nvidia Driver
I had to remove Nvidia Driver for the Dockerdriver to get work. After I done this, the packages manager told me to update over 700 packages. So i tried to update them, but sadly it fails (Conflict errors).
Im not sure what to do now…
Error message:
(714/714) checking keys in keyring        [#############################################################################] 100%
(714/714) checking package integrity        [#############################################################################] 100%
(714/714) loading package files        [#############################################################################] 100%
(714/714) checking for file conflicts        [#############################################################################] 100%
error: failed to commit transaction (conflicting files)
alpm-octopi-utils: /usr/include/alpm_octopi_utils.h exists in filesystem (owned by alpm_octopi_utils)
alpm-octopi-utils: /usr/lib/libalpm_octopi_utils.so exists in filesystem (owned by alpm_octopi_utils)
alpm-octopi-utils: /usr/lib/pkgconfig/libalpm_octopi_utils.pc exists in filesystem (owned by alpm_octopi_utils)
Edit
After removing octopi it upgraded everything… Funny because i tried to update a single package and got error aswell. Linux is a mistery
run the update again, and copy the error output here, and use formatting - click this icon in the editor: </>
You can either remove first the alpm-octopi-utils then update, or run the update with
sudo pacman -Syyu --overwrite '*'
