Wifi and Speakers not working on new 2022 AMD Laptop (UM3402YA)
I installed Manjaro Gnome Full on a new 2022 laptop. The installation process was normal as far as I know (I’m a noob). But WIFI is missing from settings, there is no option to select it or configure it. In addition the speakers aren’t producing any sound. Under sound settings the audio visualizer is working but no sound is being produced. I don’t know what else isn’t working. I installed a different Linux distro and the same problem persisted. Any hits on what I should do next?
Thanks for your help
Probably your hardware is not supported yet properly…
Provide formatted output from:
inxi -Fazy
Install the 5.18 kernel, reboot and select it in the grub menu and try with it
