Really sorry for that , will keep it in mind going forward and will format the previous ones too rightnow
Edit: Done
Edit: Done
ok good, you can now disconnect your phone, restart network manager and see if your able to connect to wifi.
-disconnect phone.
systemctl restart NetworkManager
-try and connect
ath10k_pci 61440 0
ath10k_core 532480 1 ath10k_pci
ath 36864 1 ath10k_core
mac80211 929792 1 ath10k_core
cfg80211 778240 3 ath,mac80211,ath10k_core
acer_wmi 24576 0
sparse_keymap 16384 1 acer_wmi
rfkill 28672 8 acer_wmi,bluetooth,cfg80211
acer_wireless 16384 0
i8042 32768 1 acer_wmi
wmi 28672 3 acer_wmi,wmi_bmof,dell_wmi_descriptor```
ok, you can try this first although im not sure how a live usb handles suspend but ive seen it as a temporary solution to get wifi to connect properly. close lid and let it suspend, wait 10-15 second and turn it back on and see if its able to connect.
please also post full inxi -Fnxxxz
This worked! Can finally see surrounding WiFi networks. Back at the “setting network address” loop
inxi -Fnxxxz
System: Host: manjaro Kernel: 4.19.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1
Desktop: KDE Plasma 5.14.4 tk: Qt 5.12.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Acer product: Nitro AN515-42 v: V1.11 serial: <filter>
Mobo: RR model: Freed_RRS v: V1.11 serial: <filter> UEFI: Insyde v: 1.11 date: 10/30/2018
Battery: ID-1: BAT1 charge: 48.6 Wh condition: 48.6/48.9 Wh (99%) volts: 17.0/15.2
model: LG 41,43,31,34,42,38,4B type: Li-ion serial: <filter> status: Full
CPU: Topology: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP
arch: Zen L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31952
Speed: 2541 MHz min/max: 1600/2000 MHz Core speeds (MHz): 1: 2350 2: 2388 3: 1782 4: 1550 5: 1394
6: 1395 7: 1394 8: 1385
Graphics: Device-1: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus ID: 01:00.0 chip ID: 1002:67ef
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel bus ID: 04:00.0 chip ID: 1002:15dd
Display: x11 server: X.Org 1.20.3 driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
compositor: kwin_x11 resolution: 1920x1080~60Hz
OpenGL: renderer: AMD RAVEN (DRM 3.27.0 4.19.13-1-MANJARO LLVM 7.0.0) v: 4.5 Mesa 18.3.1
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus ID: 04:00.1 chip ID: 1002:15de
Device-2: Advanced Micro Devices [AMD] vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus ID: 04:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k4.19.13-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI
driver: r8169 v: kernel port: 2000 bus ID: 02:00.1 chip ID: 10ec:8168
IF: enp2s0f1 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Lite-On
driver: ath10k_pci v: kernel port: 2000 bus ID: 03:00.0 chip ID: 168c:003e
IF: wlp3s0 state: down mac: <filter>
IF-ID-1: enp4s0f4u2 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives: Local Storage: total: 938.74 GiB used: 169.1 MiB (0.0%)
ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-21Z10T0 size: 931.51 GiB speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1A02 scheme: GPT
ID-2: /dev/sdb type: USB vendor: SanDisk model: Cruzer Blade size: 7.23 GiB serial: <filter>
rev: 1.27 scheme: MBR
Partition: ID-1: / size: 5.03 GiB used: 169.1 MiB (3.3%) fs: overlay source: ERR-102
Sensors: System Temperatures: cpu: 48.5 C mobo: N/A
GPU: device: amdgpu temp: 48 C device: amdgpu temp: 44 C
Info: Processes: 294 Uptime: 1h 08m Memory: 6.70 GiB used: 1.92 GiB (28.7%) Init: systemd v: 239 Compilers:
gcc: 8.2.1 Shell: bash v: 4.4.23 running in: konsole inxi: 3.0.28```
courtesy of tbg’s previous posts, just slightly modified for you system.
Issue these commands one after the other with a few seconds between each command:
sudo systemctl stop NetworkManager sudo ip link set wlp3s0 down sudo modprobe -r acer_wireless ath10k_core ath10k_pci dell_wmi_descriptor
Then issue:
sudo modprobe ath10k_core ath10k_pci sudo ip link set wlp3s0 up sudo systemctl start NetworkManager
Be sure to post the input and output of each command issued.
for the first set of commands
modprobe: FATAL: Module ath10k_core is in use.
issued all the commands .
[manjaro@manjaro ~]$ sudo ip link set wlp3s0 down
[manjaro@manjaro ~]$ sudo modprobe -r acer_wireless ath10k_core ath10k_pci dell_wmi_descriptor
[manjaro@manjaro ~]$ sudo modprobe ath10k_core ath10k_pci
[manjaro@manjaro ~]$ sudo ip link set wlp3s0 up
[manjaro@manjaro ~]$ sudo systemctl start NetworkManager
[manjaro@manjaro ~]$ ```
so i will do this ?
sudo modprobe ath10k_pci
sudo modprobe -r acer_wireless ath10k_pci dell_wmi_descriptor
the output from the modified commands
[manjaro@manjaro ~]$ sudo modprobe -r acer_wireless ath10k_pci dell_wmi_descriptor
[manjaro@manjaro ~]$ sudo modprobe ath10k_pci
[manjaro@manjaro ~]$ sudo systemctl start NetworkManager```
no luck , tried
rfkill unblock all
too. The same setting network address loop . If it helps , i tried using manjaro architect afterwards and using it to connect it said Could not activate connection: Activation failed: IP configuration could not be reserved (no available address, timeout, etc.)
can you post this again
lsmod | grep 'ath\|acer'
also just to be sure, you have not rebooted right?
Nope no reboots since we started .
[manjaro@manjaro ~]$ lsmod | grep 'ath\|acer'
ath10k_pci 61440 0
acer_wmi 24576 0
rfkill 28672 10 acer_wmi,bluetooth,cfg80211
wmi 28672 2 acer_wmi,wmi_bmof
