WiFi and soft lockup issues in Acer Nitro 5
#1
Ryzen 2500u + Rx560x
Latest manjaro stable iso
Attempt to liveboot the iso
Free drivers causes Soft Lockups on CPU5
Non free drivers hasn’t till now but idk
Cant connect to Password protected WiFi
It shows Stuck on Setting Network Address for a while before it disconnects
Connecting to open WiFi From my phone works
The wifi adapter is qca61x4a
Qualcomm WiFi suddenly not working
#2
did you try and search the forum for related threads .?
#3
That specific thread doesnt inspire much confidence about the linux compatibility of my laptop :frowning:
A quick search doesnt show much about wifi while theres a lot of discussion about soft lockups. The liveboot session with non free drivers for me was pretty stable, only the wifi issues held me back from installing for good
#4
i’ll take a took, i have not read that thread as i primarily use an intel/nvidia optimus lappy which itself can be a task for a newcomer to set up. a lot of these issues are solved with kernel parameters added to grub which is also what i need to do to even be able t boot to a graphical desktop without freezing.
can you explain a bit more about when the lockups occur (what your doing when it happens). and also some system info will be helpful. inxi -Fnxxxz and anything else relevant you see here:
dont forget to put three backtics above and below terminal output so its formatted properly, alternatively you can also hit the </> button above the post entry box and paste the output. i’ll take a quick look to see if i can find anything to resolve your current issue.
this thread here is more likely to answer your issues.
#5
well the lockups happen while booting using the free drivers . Cant even see the desktop.
I can boot fine using non free drivers for now.
Livebooting rightnow to give the inxi - Fnxxz output
#6
hold on.
when you get to the welcome menu where you choose free/nonfree, make your selection and then move the selector to where it says boot but dont hit enter, instead hit e and then find the word quiet then delete it and add the following kernel parameters and make sure there is a space left before and after both of them.
iommu=soft and idle=nomwait
then hit CTRL+X to boot
#7
Doing this rightnow, will report back . Should i use free drivers then ?
Edit - Ofcourse it will boot with Free drivers, saw it mentioned along with Quiet . Sorry for the noob mistakes
#8
i believe free but i could be wrong. i think free is the popular choice for amd and adding amdgpu later is an option. again, im not sure. if you want to see exactly what drivers manjaro hardware detection lists as compatible with your gpu just enter mhwd in the terminal and it will list compatible drivers.
just remember that if those parameters work, they only work for that boot and if you reboot will need to be added back in. after your finished installing to make them permanent you would just edit /etc/default/grub
Kernel Boot Parameter
Adding a kernel boot parameter for GRUB in Manjaro:
  1. Open the file /etc/default/grub in a text editor.
  2. Add the parameter, in this case idle=nomwait (notice the m ), to the line starting with GRUB_CMDLINE_LINUX_DEFAULT="<current parameters ...> idle=nomwait iommu=soft" .
  3. Save the file.
  4. Update GRUB: sudo update-grub .
  5. Upon next reboot the default boot option should include the parameter.
#9
Did what you said , booted with free drivers for the first time
#10
nice, glad it worked out. is your wifi working?
#11
It showed the available WiFi networks for the first 10 seconds, had the same issue with protected WiFi as before . And then it just died. Dmesg shows a lot of Ath10k related failures
#12
this is no surprise, there are a bunch of threads on them that @tbg is great at resolving. just do a forum search and you’ll probably find your solution. i’ll also take a look.
you might want to get manjaro installed/updated first since any changes made will need to be repeated after rebooting since you in a live environment it resets each boot.
can you copy/paste dmesg | grep ath10 so we know exactly what issue its having.
#13
I am typing from my phone rightnow . Tried using mtp to copy the dmesg to phone before uploading but it seems the PC can’t write to it
#14
you were previously able to connect through hotspot/tether on your phone right?
also in terminal copy/paste output
rfkill list all
journalctl -b 0 -o cat | grep NetworkManager
#15
The mtp issue resolved itself somehow .
[   11.970195] ath10k_pci 0000:03:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   12.288994] ath10k_pci 0000:03:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 11ad:0807
[   12.288997] ath10k_pci 0000:03:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[   12.289417] ath10k_pci 0000:03:00.0: firmware ver RM.4.4.1.c2-00057-QCARMSWP-1 api 6 features wowlan,ignore-otp,no-4addr-pad,raw-mode crc32 e061250a
[   12.358264] ath10k_pci 0000:03:00.0: board_file api 2 bmi_id N/A crc32 20d869c3
[   12.938846] ath10k_pci 0000:03:00.0: Unknown eventid: 118809
[   12.941083] ath10k_pci 0000:03:00.0: htt-ver 3.56 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[   13.039461] ath10k_pci 0000:03:00.0 wlp3s0: renamed from wlan0
[   15.384681] ath10k_pci 0000:03:00.0: Unknown eventid: 118809
[   16.222638] ath10k_pci 0000:03:00.0: Unknown eventid: 118809
[  142.959324] ath10k_pci 0000:03:00.0: failed to receive scan abortion completion: timed out
[  142.959342] ath10k_pci 0000:03:00.0: failed to abort scan: -110
[  148.076319] ath10k_pci 0000:03:00.0: failed to synchronize setup for vdev 0 restart 0: -110
[  148.076326] ath10k_pci 0000:03:00.0: failed to start vdev 0 addr 00:f4:8d:9e:73:d5 on freq 2442: -110
[  151.276320] ath10k_pci 0000:03:00.0: wmi command 20483 timeout, restarting hardware
[  151.276333] ath10k_pci 0000:03:00.0: failed to start WMI vdev 0: -11
[  151.276339] ath10k_pci 0000:03:00.0: failed to start vdev 0 addr 00:f4:8d:9e:73:d5 on freq 2442: -11
[  151.282808] ath10k_pci 0000:03:00.0: failed to delete WMI vdev 0: -108
[  151.283171] ath10k_pci 0000:03:00.0: failed to create WMI vdev 0: -108
[  151.304792] ath10k_pci 0000:03:00.0: failed to read hi_board_data address: -16
[  151.508676] ath10k_pci 0000:03:00.0: Failed to get pcie state addr: -16
[  151.508684] ath10k_pci 0000:03:00.0: failed to setup init config: -16
[  151.508785] ath10k_pci 0000:03:00.0: Could not init hif: -16
[  151.508858] Modules linked in: cmac fuse rfcomm sg st sr_mod cdrom bnep arc4 btusb uvcvideo btrtl btbcm btintel videobuf2_vmalloc videobuf2_memops bluetooth videobuf2_v4l2 videobuf2_common videodev media ecdh_generic crc16 amdkfd amd_iommu_v2 amdgpu dcdbas dell_wmi_descriptor ath10k_pci ath10k_core chash snd_hda_codec_realtek snd_hda_codec_generic joydev mousedev snd_hda_codec_hdmi gpu_sched snd_hda_intel ath hid_multitouch i2c_algo_bit mac80211 edac_mce_amd snd_hda_codec ttm hid_generic kvm_amd snd_hda_core drm_kms_helper ccp snd_hwdep snd_pcm snd_timer drm cfg80211 snd kvm agpgart syscopyarea soundcore rtsx_pci_ms sysfillrect sysimgblt irqbypass memstick crct10dif_pclmul sp5100_tco ghash_clmulni_intel acer_wmi fb_sys_fops sparse_keymap i2c_piix4 wmi_bmof pcspkr rfkill k10temp input_leds i2c_hid
[  151.509151] Modules linked in: cmac fuse rfcomm sg st sr_mod cdrom bnep arc4 btusb uvcvideo btrtl btbcm btintel videobuf2_vmalloc videobuf2_memops bluetooth videobuf2_v4l2 videobuf2_common videodev media ecdh_generic crc16 amdkfd amd_iommu_v2 amdgpu dcdbas dell_wmi_descriptor ath10k_pci ath10k_core chash snd_hda_codec_realtek snd_hda_codec_generic joydev mousedev snd_hda_codec_hdmi gpu_sched snd_hda_intel ath hid_multitouch i2c_algo_bit mac80211 edac_mce_amd snd_hda_codec ttm hid_generic kvm_amd snd_hda_core drm_kms_helper ccp snd_hwdep snd_pcm snd_timer drm cfg80211 snd kvm agpgart syscopyarea soundcore rtsx_pci_ms sysfillrect sysimgblt irqbypass memstick crct10dif_pclmul sp5100_tco ghash_clmulni_intel acer_wmi fb_sys_fops sparse_keymap i2c_piix4 wmi_bmof pcspkr rfkill k10temp input_leds i2c_hid
[  151.509434] Modules linked in: cmac fuse rfcomm sg st sr_mod cdrom bnep arc4 btusb uvcvideo btrtl btbcm btintel videobuf2_vmalloc videobuf2_memops bluetooth videobuf2_v4l2 videobuf2_common videodev media ecdh_generic crc16 amdkfd amd_iommu_v2 amdgpu dcdbas dell_wmi_descriptor ath10k_pci ath10k_core chash snd_hda_codec_realtek snd_hda_codec_generic joydev mousedev snd_hda_codec_hdmi gpu_sched snd_hda_intel ath hid_multitouch i2c_algo_bit mac80211 edac_mce_amd snd_hda_codec ttm hid_generic kvm_amd snd_hda_core drm_kms_helper ccp snd_hwdep snd_pcm snd_timer drm cfg80211 snd kvm agpgart syscopyarea soundcore rtsx_pci_ms sysfillrect sysimgblt irqbypass memstick crct10dif_pclmul sp5100_tco ghash_clmulni_intel acer_wmi fb_sys_fops sparse_keymap i2c_piix4 wmi_bmof pcspkr rfkill k10temp input_leds i2c_hid
[  232.445292] ath10k_pci 0000:03:00.0: Failed to get pcie state addr: -16
[  232.445299] ath10k_pci 0000:03:00.0: failed to setup init config: -16
[  232.445397] ath10k_pci 0000:03:00.0: Could not init hif: -16
[  232.585006] ath10k_pci 0000:03:00.0: Failed to get pcie state addr: -16
[  232.585014] ath10k_pci 0000:03:00.0: failed to setup init config: -16
[  232.585109] ath10k_pci 0000:03:00.0: Could not init hif: -16
[  398.858649] ath10k_pci 0000:03:00.0: Failed to get pcie state addr: -16
[  398.858659] ath10k_pci 0000:03:00.0: failed to setup init config: -16
[  398.858760] ath10k_pci 0000:03:00.0: Could not init hif: -16
[  398.995304] ath10k_pci 0000:03:00.0: Failed to get pcie state addr: -16
[  398.995312] ath10k_pci 0000:03:00.0: failed to setup init config: -16
[  398.995413] ath10k_pci 0000:03:00.0: Could not init hif: -16```
#16
almost got it :grin:. three ``` above and below the terminal output you copy and pasted
#17
0: acer-wireless: Wireless LAN
        Soft blocked: yes
        Hard blocked: no
1: acer-bluetooth: Bluetooth
        Soft blocked: no
        Hard blocked: no
2: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
3: phy0: Wireless LAN
        Soft blocked: yes
        Hard blocked: no
<info>  [1548188788.9088] NetworkManager (version 1.14.5dev+17+gba83251bb-1) is starting... (for the first time)
<info>  [1548188788.9089] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
<info>  [1548188788.9339] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.7' (uid=0 pid=769 comm="/usr/bin/NetworkManager --no-daemon ")
SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
<info>  [1548188789.2042] settings: Loaded settings plugin: NMSIbftPlugin ("/usr/lib/NetworkManager/1.14.5dev+17+gba83251bb-1/libnm-settings-plugin-ibft.so")
<info>  [1548188789.2283] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.14.5dev+17+gba83251bb-1/libnm-device-plugin-adsl.so)
<info>  [1548188789.2527] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.14.5dev+17+gba83251bb-1/libnm-device-plugin-bluetooth.so)
<info>  [1548188789.2648] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.14.5dev+17+gba83251bb-1/libnm-device-plugin-ovs.so)
<info>  [1548188789.4036] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.14.5dev+17+gba83251bb-1/libnm-device-plugin-team.so)
<info>  [1548188789.4210] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.14.5dev+17+gba83251bb-1/libnm-device-plugin-wifi.so)
<info>  [1548188789.4212] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.14.5dev+17+gba83251bb-1/libnm-device-plugin-wwan.so)
<info>  [1548188789.4223] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
<info>  [1548188789.4232] manager: (enp2s0f1): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
<info>  [1548188789.4252] keyfile: add connection /var/run/NetworkManager/system-connections/Wired connection 1.nmconnection (3c3a478c-a2a9-3dd7-9b30-253cf3e16cf6,"Wired connection 1")
<info>  [1548188789.5724] manager: (wlp3s0): new 802.11 WiFi device (/org/freedesktop/NetworkManager/Devices/3)
[system] Activating via systemd: service name='fi.w1.wpa_supplicant1' unit='wpa_supplicant.service' requested by ':1.7' (uid=0 pid=769 comm="/usr/bin/NetworkManager --no-daemon ")
SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
audit: type=1131 audit(1548188799.923:41): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
<info>  [1548188894.0533] keyfile: add connection /var/run/NetworkManager/system-connections/pramod.nmconnection (aa5afb22-7b90-4e74-ac3f-3bd2fadadb2f,"pramod")
<info>  [1548188894.0560] settings-connection[0x55a735e7cb50,aa5afb22-7b90-4e74-ac3f-3bd2fadadb2f]: write: successfully commited (keyfile: update /etc/NetworkManager/system-connections/pramod.nmconnection (aa5afb22-7b90-4e74-ac3f-3bd2fadadb2f,"pramod") and rename from "/var/run/NetworkManager/system-connections/pramod.nmconnection")
USYS_CONFIG pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-add-activate uuid=aa5afb22-7b90-4e74-ac3f-3bd2fadadb2f name="pramod" pid=1707 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
audit: type=1111 audit(1548188894.050:57): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-add-activate uuid=aa5afb22-7b90-4e74-ac3f-3bd2fadadb2f name="pramod" pid=1707 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
<info>  [1548188894.0605] manager: NetworkManager state is now CONNECTING
plasma-nm: Path: "/org/freedesktop/NetworkManager/Settings/2"
<info>  [1548188918.9063] manager: NetworkManager state is now DISCONNECTED
USYS_CONFIG pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=1707 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
audit: type=1111 audit(1548189005.980:58): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=1707 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
audit: type=1111 audit(1548189007.343:60): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=1707 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
audit: type=1111 audit(1548189172.396:62): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=1707 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
USYS_CONFIG pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wwan-enabled" pid=1707 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
audit: type=1111 audit(1548189172.400:63): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wwan-enabled" pid=1707 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
audit: type=1111 audit(1548189173.756:65): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=1707 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
audit: type=1111 audit(1548189173.900:66): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wwan-enabled" pid=1707 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
audit: type=1111 audit(1548189173.933:67): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=1707 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
audit: type=1111 audit(1548189173.936:68): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wwan-enabled" pid=1707 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
<info>  [1548189225.6442] settings-connection[0x55a735e7cb50,aa5afb22-7b90-4e74-ac3f-3bd2fadadb2f]: write: successfully updated (keyfile: update /etc/NetworkManager/system-connections/pramod.nmconnection (aa5afb22-7b90-4e74-ac3f-3bd2fadadb2f,"pramod"))
USYS_CONFIG pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-update uuid=aa5afb22-7b90-4e74-ac3f-3bd2fadadb2f name="pramod" args=802-11-wireless-security.auth-alg,802-11-wireless.mode,802-11-wireless.band,802-11-wireless.channel pid=2072 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
audit: type=1111 audit(1548189225.640:70): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-update uuid=aa5afb22-7b90-4e74-ac3f-3bd2fadadb2f name="pramod" args=802-11-wireless-security.auth-alg,802-11-wireless.mode,802-11-wireless.band,802-11-wireless.channel pid=2072 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
<info>  [1548190176.5268] manager: (usb0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/4)
<info>  [1548190177.1098] keyfile: add connection /var/run/NetworkManager/system-connections/Wired connection 2.nmconnection (554fbcf1-82f4-32d7-88eb-deb0a150db0e,"Wired connection 2")
<info>  [1548190177.1225] manager: NetworkManager state is now CONNECTING
<warn>  [1548190177.1247] secret-key: failure reading secret key in "/var/lib/NetworkManager/secret_key": Failed to open file “/var/lib/NetworkManager/secret_key”: No such file or directory (generate new key)
<info>  [1548190180.0289] manager: NetworkManager state is now CONNECTED_LOCAL
<info>  [1548190180.0295] manager: NetworkManager state is now CONNECTED_SITE
audit: type=1130 audit(1548190180.043:76): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
<info>  [1548190180.3808] manager: NetworkManager state is now CONNECTED_GLOBAL
USYS_CONFIG pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=1707 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
audit: type=1111 audit(1548190188.036:77): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=1707 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
audit: type=1131 audit(1548190189.910:78): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
audit: type=1111 audit(1548190192.776:79): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=1707 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success' ```
#18
ok, do you have a wifi key on the keyboard? Fn+F3 or whichever is the one you have. your goal is to have the output of rfkill list all not output any yes’s. you want to see only no’s so try and use that button/buttons for both wifi and/or bluetooth until the output of rfkill list all is all no’s
or better yet you can do this
sudo rfkill unblock wifi
sudo rfkill unblock bluetooth
and check rfkill again
#19
ok did what you said , had to do it twice to get this output
        Soft blocked: no
        Hard blocked: no
        Soft blocked: no
        Hard blocked: no
2: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
        Soft blocked: no
        Hard blocked: no
#20
ok thats a step forward at least. please format the outputs properly. 3 backtics ``` above and below outputs. otherwise its too difficult to make sense of
you can also hit that </> button and then paste. or highligh and then hit </>
