WiFi Adapter Not Found After Fresh Manjaro GNOME Installation
I have a HP Victus RTX 3050 variant laptop and I had installed Manjaro GNOME on it yesterday.
I booted in after installing and noticed that I could not connect to WiFi as it wasn’t an option in the settings.
On manually searching through the searchbar, I found the WiFi option but on clicking it, it gave me an message: “No WiFi Adapter Found”
I ran through the forums and it all spoke about downloading the drivers from the AUR but I could not find my WiFi drivers while searching through the terminal for the Driver Name:
Here is the output of the command : inxi -Fz
inxi -Fz
  Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 Desktop: GNOME 41.2
    Distro: Manjaro Linux
  Type: Laptop System: HP product: Victus by HP Laptop 16-e0xxx v: N/A
    serial: <superuser required>
  Mobo: HP model: 88EC v: 80.56 serial: <superuser required> UEFI: AMI
    v: F.09 date: 07/16/2021
  ID-1: BAT0 charge: 61.6 Wh (92.5%) condition: 66.6/66.6 Wh (100.0%)
  Info: 6-core model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64
    type: MT MCP cache: L2: 3 MiB
  Speed (MHz): avg: 1493 min/max: 1200/3300 cores: 1: 1198 2: 1778 3: 1547
    4: 1261 5: 1198 6: 1197 7: 1197 8: 1197 9: 2292 10: 2003 11: 1198 12: 1858
  Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] driver: nvidia v: 495.44
  Device-2: AMD Cezanne driver: amdgpu v: kernel
  Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
  Display: x11 server: X.org 1.21.1.2 driver: loaded: amdgpu,ati,nvidia
    unloaded: modesetting,nouveau,radeon resolution: <missing: xdpyinfo>
  Device-1: NVIDIA driver: snd_hda_intel
  Device-2: AMD driver: snd_hda_intel
  Device-3: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
    driver: snd_rn_pci_acp3x
  Device-4: AMD Family 17h HD Audio driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
  Sound Server-2: PulseAudio v: 15.0 running: yes
  Sound Server-3: PipeWire v: 0.3.42 running: yes
    driver: r8169
  Device-2: Realtek driver: N/A
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb
  Local Storage: total: 476.94 GiB used: 9.86 GiB (2.1%)
  ID-1: /dev/nvme0n1 vendor: Western Digital
    model: PC SN730 SDBPNTY-512G-1006 size: 476.94 GiB
  ID-1: / size: 97.87 GiB used: 9.64 GiB (9.8%) fs: ext4 dev: /dev/nvme0n1p6
  ID-2: /boot/efi size: 511 MiB used: 288 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p7
  ID-3: /home size: 58.26 GiB used: 223.6 MiB (0.4%) fs: ext4
    dev: /dev/nvme0n1p8
  System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
  Processes: 313 Uptime: 31m Memory: 7.17 GiB used: 1.98 GiB (27.6%)
  Shell: Zsh inxi: 3.3.11
Could anyone help me out here ? :sweat_smile:
Thanks in advance
Update: I’ve removed Manjaro. I couldn’t wait for much longer as needed it to work quite quickly.
Thanks for the help. I don’t know how to close this post so I decided to post an update instead.
Open the Manjaro Software Manager and install it from there.
I did try that. It says Unknown device name and no option to install drivers
