Hi all,
I have exactly the same issue.
I’ve been using manjaro without this problem for the last year with kernel 5.8.
Had to reinstall due to a disc failure and used the latest iso from the web: Manjaro x86_64 20.2.1 Nibia
After that, wifi adapter is not working randomly at start (login screen) and the “wifi” setting does not even appear on the “settings” menu list when already logged
Looks like the adapter is not “supported” but happens only randomly.
Using “lshw” i can see it listed when it is not working.
On dual boot it works with a windows OS.
I did read somewhere, this could be a kernel (5.9) issue not supporting the HW fully, so i updated to kernel 5.10 but the problem remains, also booted with 5.8 and same issue is happening, while this never happened before.
Did something else, related to this, change on 20.2.1 nibia?
Being random is driving me a bit crazy because i have no clue how to locate the problem.
This is “inxi -Fazy” output:
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=27ba6cde-fa39-41b1-a203-b0147cd3b42c rw quiet apparmor=1
Desktop: GNOME 3.38.2 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: Z390 AORUS ULTRA v: N/A
serial: <filter>
Mobo: Gigabyte model: Z390 AORUS ULTRA-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F7 date: 03/14/2019
Info: 8-Core model: Intel Core i7-9700K bits: 64 type: MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: D (13) microcode: DE
L2 cache: 12 MiB
bogomips: 57616
Speed: 800 MHz min/max: 800/4900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Type: srbds mitigation: TSX disabled
Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1e81
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver: nvidia
OpenGL: renderer: GeForce RTX 2080 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:10f8
Sound Server: ALSA v: k5.10.2-2-MANJARO
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
bus ID: 00:14.3 chip ID: 8086:a370
Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: efa0 bus ID: 00:1f.6 chip ID: 8086:15bc
IF: eno2 state: down mac: <filter>
Local Storage: total: 1.84 TiB used: 721.63 GiB (38.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: AAGA4102 temp: 37.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO M.2 1TB
size: 931.51 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 4B6Q
ID-1: / raw size: 384.77 GiB size: 377.73 GiB (98.17%)
used: 165.38 GiB (43.8%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw size: 100 MiB size: 96 MiB (96.00%)
used: 25.1 MiB (26.2%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 30 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Processes: 261 Uptime: 2h 35m wakeups: 0 Memory: 15.57 GiB
used: 2.4 GiB (15.4%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1444 lib: 471 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.2.01
Anyone has any idea what’s happening or how to locate where is the problem?
Hope having more info can help us find a solution as it seems to be the same problem.
Thanks!
