Widgets in Manjaro?
Can you recommend widget software for Manjaro that might duplicate the type of widgets (news, etc.) that one finds in Windows? Thanks.
Well Plasma has quite a number of desktop widgets. I don’t use any of them. For example I get my news via an rss feed through my email client (claws-mail), from there I automagically open links to a specific instance of firefox.
The GNOME DE should also have widgets. I assume they can be downloaded.
I can’t recommend any as I don’t really know what you’re after and I have no idea what Windows provides.
I can’t, because I think every widget that you place takes up cpu cycles and increases load and complication.
For ā€˜news etc’ I use Innoreader - so that comes through in a feed visible in Firefox, with notification badges of unread items.
My last experience with Windows was the sidebar in Vista, I spent a week setting it up, and then purged the whole thing and turned of all the desktop effects to make it run smooth.
With Plasma, I don’t need to turn everything off, but I’m still reluctant… I have conky displays for my networking, cpu/ram use, clock, last backup, rtcwake time if set, and disk use… along with the day and date.
Weather widgets suck as do most others.
Plasma has widgets, and you can download more - but YMMV, some are good, others are buggy and old.
Weather widgets are mostly useless, especially where I live. Actually I have never found a weather widget that was useful.
Widgets are so unpopular that Microsoft actually removed them in the newer windows versions. Let’s be honest: one looks once on them at boot time, and then places windows over them (but they keep using cpu).
I guess the closest to universal widget is Conky, with gazillions of variants. The only drawback that it is noninteractive.
Wow, you can spot a non-conky user :wink:
I’ll be honest, I did try a couple of conky configs - but the best is when you scrap them all and just focus on things you want to see.
Day/date and a clock that stays on top?
CPU/RAM and networkup/down
Screenshot_20260425_183637
Storage and a bit of interesting information…
Screenshot_20260425_183714
I mean that’s enough, I have a ā€˜processes’ conky - but that only lasts for a minute after starting, as does my ā€˜notes’ which is useful to paste a bunch of keyboard shortcuts I’m trying to learn.
Here’s Yazi:
Right. I tried the weather widget. It was a memory hog and provided no additional info. :slight_smile:
I find the one I’m using in Plasma to be pretty accurate. But, in my case, I have it set to a weather station roughly ¾ of a mile away. I guess your nearest station is likely rather further away than that. :wink:
It does display the sun or the moon-phase at the wrong times, though, and differently to my other machine. :roll_eyes:
This is the list of Gnome Extensions I use:
āÆ gnome-extensions list --enabled
dash-to-panel@jderose9.github.com
tailscale-gnome-qs@tailscale-qs.github.io
appindicatorsupport@rgcjonas.gmail.com
auto-move-windows@gnome-shell-extensions.gcampax.github.com
gnome-ui-tune@itstime.tech
legacyschemeautoswitcher@joshimukul29.gmail.com
user-theme@gnome-shell-extensions.gcampax.github.com
screenshot-window-sizer@gnome-shell-extensions.gcampax.github.com
easy_docker_containers@red.software.systems
arcmenu@arcmenu.com
dash-to-dock@micxgx.gmail.com
gsconnect@andyholmes.github.io
Maintainers do an amazing job keeping these extensions alive, even during Gnome version bumps their work is exceptional. I recommend them all :smiley:
P.S. For gaming you might want to add the Gamemode Extension
