Widevine error?
When trying to install widevine-aarch64 I get the following error:
glibc needs to be removed but it is a locked package
How do I fix this? Thanks.
install or build from AUR?
Sorry should have been more clear that’s the error I get when either building or installing from AUR
do you build glibc-widevine, WARNing its big.
I get the same error message
Does anyone know how to fix this?
Now its saying it’s not even available?
no such issue, i build myself form AUR.
Hello,
I am getting the same error when trying to install glibc-widevine and widevine-aarch64 from AUR on my pinebook pro.
I am running sudo pamac build widevine-aarch64 glibc-widevine to try to install them, but right after the dependencies check for glibc-widevine, I get this error:
Resolving dependencies...
Checking inter-conflicts...
Error: Failed to prepare transaction: - glibc needs to be removed but it is a locked package
I fixed it by cloning from aur and building it from there. was having issues getting it to work but an update fixed those too. all is running fine now
