Hey guys, first of all I’m pretty new to linux/manjaro so be gentle.
So, I updated my system drivers and after rebooting my system none of my Wi-Fi connections are showing up, I’m pretty sure the Wi-Fi drivers are messed up but I have no idea how to fix it. I tried downgrading kernel version but ended up with nothing. Let me know what you need from me to debug this problem. Thanks in advance.
Welcome to the forum!
By doing what, exactly? Most drivers are provided by the kernel.
Bad idea. You can have more than one kernel installed. See Manjaro Kernels - Manjaro
Please see:
pacman -Syu , I guess thats updating applications itself and not the drivers? My bad?
Okay, after looking into posts similar to my situation I thought it could have been a possible fix. This is my current version:
Currently running: 5.10.117-1-MANJARO (linux510)
- linux510
This my Network Devices information, I think the problem could be because my adapter driver is N/A? I have no idea at this point
Device-1: Intel Wireless 8265 / 8275 driver: N/A modules: iwlwifi, wl pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
class-ID: 0280
Device-2: Intel Bluetooth wireless interface type: USB driver: btusb
bus-ID: 1-8:6 chip-ID: 8087:0a2b class-ID: e001
I can’t upload images so I’m just copying the terminal output
provide formated output, click this icon in editor: </>
inxi -Fazy
was the driver installed from AUR
Kernel: 5.10.117-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=901c13ac-fa35-495d-8e54-b86b5590c497 rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook S15 X530UF v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: X530UF v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X530UF.305 date: 05/21/2019
ID-1: BAT0 charge: 31.7 Wh (100.0%) condition: 31.7/42.1 Wh (75.3%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 410
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Info: model: Intel Core i3-8130U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 900 min/max: 400/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 bogomips: 17605
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX130] vendor: ASUSTeK driver: nouveau
v: kernel non-free: 515.xx+ status: current (as of 2022-05) arch: Maxwell
pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s
bus-ID: 01:00.0 chip-ID: 10de:174d class-ID: 0302
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:5 chip-ID: 13d3:56c1 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x81ec built: 2018 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.10.117-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
class-ID: 0280
IF-ID-1: enp0s20f0u1c4i2 state: up speed: N/A duplex: N/A mac: <filter>
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 1.36 TiB used: 19.76 GiB (1.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20WD
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Toshiba model: MQ04ABF100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: HDD
rpm: 5400 serial: <filter> rev: 7601 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 19.76 GiB (2.2%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
System Temperatures: cpu: 50.0 C pch: 39.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2600
Processes: 229 Uptime: 28m wakeups: 3 Memory: 7.65 GiB
used: 1.85 GiB (24.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 1155 pacman: 1140 lib: 344 flatpak: 0
snap: 15 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.16
I’m not sure if I even have a driver installed to be honest, I installed one after it stopped working through the Add/Remove Software but that didn’t do anything.
intsall the 5.17 kernel, reboot, select it in grub, and check if it works with it
It started working again out of the sudden. Ok i guess?? I’m still on 5.10 kernel
