Wi-Fi needs turning off/on after waking
Hello Everyone
Manjaro KDE works well on my 2017 MacBook Air - very pleasing after many failures with Mint and Ubuntu. The only problem is that when I open the lid to continue a session, the wi-fi has disconnected and needs ages to reconnect, if at all. I discovered that hitting ‘Disconnect’ then ‘Connect’ in Networks does the trick every time. While the problem is there I sometimes get ‘wlp3s0 missing’.
Here is inxi -Fza:
  Kernel: 5.11.4-1-rt11-MANJARO x86_64 bits: 64 compiler: gcc
  v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-rt-x86_64
  root=UUID=a8fda7dc-15ab-4a3c-86fd-ad1af3db9c3f rw quiet
  apparmor=1 security=apparmor
  resume=UUID=5fc45327-890e-4e7f-ba1c-5c4a63bfd8ce
  udev.log_priority=3
  Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1
  Type: Laptop System: Apple product: MacBookAir7,2 v: 1.0
  serial: <filter> Chassis: type: 9 v: Mac-937CB26E2E02BB01
  serial: <filter>
  Mobo: Apple model: Mac-937CB26E2E02BB01 v: MacBookAir7,2
  serial: <filter> UEFI: Apple v: 427.140.8.0.0 date: 06/13/2021
  ID-1: BAT0 charge: 22.8 Wh (46.5%)
  condition: 49.0/54.3 Wh (90.1%) volts: 7.4 min: 7.6
  model: DP bq20z451 type: Li-ion serial: N/A status: Discharging
  cycles: 698
  Info: Dual Core model: Intel Core i5-5350U
  socket: BGA1168 (U3E1) note: check bits: 64 type: MT MCP
  arch: Broadwell family: 6 model-id: 3D (61) stepping: 4
  microcode: 2F cache: L1: 64 KiB L2: 3 MiB L3: 3 MiB
  bogomips: 14405
  Speed: 1600 MHz min/max: 500/2900 MHz base/boost: 2700/1800
  volts: 1.0 V ext-clock: 25 MHz Core speeds (MHz): 1: 1600
  2: 1704 3: 1633 4: 1700
  Type: l1tf mitigation: PTE Inversion; VMX: conditional cache
  flushes, SMT vulnerable
  Type: spec_store_bypass mitigation: Speculative Store Bypass
  disabled via prctl and seccomp
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and
  __user pointer sanitization
  Type: spectre_v2 mitigation: Full generic retpoline, IBPB:
  conditional, IBRS_FW, STIBP: conditional, RSB filling
  Type: tsx_async_abort
  mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: Intel HD Graphics 6000 vendor: Apple driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:1626 class-ID: 0300
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: intel unloaded: modesetting alternate: fbdev,vesa
  display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1440x900 s-dpi: 96
  s-size: 381x238mm (15.0x9.4") s-diag: 449mm (17.7")
  Monitor-1: eDP1 res: 1440x900 hz: 60 dpi: 126
  size: 290x180mm (11.4x7.1") diag: 341mm (13.4")
  OpenGL: renderer: Mesa Intel HD Graphics 6000 (BDW GT3)
  v: 4.6 Mesa 21.1.5 direct render: Yes
  Device-1: Intel Broadwell-U Audio vendor: Apple
  driver: snd_hda_intel v: kernel bus-ID: 00:03.0
  chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  chip-ID: 8086:9ca0 class-ID: 0403
  Device-3: Broadcom 720p FaceTime HD Camera driver: N/A
  bus-ID: 02:00.0 chip-ID: 14e4:1570 class-ID: 0480
  Sound Server-1: ALSA v: k5.11.4-1-rt11-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.32 running: yes
  Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter
  vendor: Apple driver: wl v: kernel modules: bcma port: efa0
  bus-ID: 03:00.0 chip-ID: 14e4:43a0 class-ID: 0280
  Device-1: Apple Bluetooth USB Host Controller type: USB
  driver: btusb v: 0.8 bus-ID: 1-3.3:6 chip-ID: 05ac:828f
  class-ID: fe01
  Report: rfkill ID: hci0 rfk-id: 1 state: up
  address: see --recommends
  Local Storage: total: 232.51 GiB used: 11.54 GiB (5.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0128G
  family: SD/SM/TS...E/F/G SSDs size: 113 GiB block-size:
  physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 3A0Q scheme: GPT
  SMART: yes state: disabled
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Samsung
  model: Flash Drive FIT size: 119.51 GiB block-size:
  physical: 512 B logical: 512 B type: SSD serial: <filter>
  rev: 1100 scheme: GPT
  SMART Message: Unknown USB bridge. Flash drive/Unsupported
  enclosure?
  ID-1: / raw-size: 110.41 GiB size: 108.11 GiB (97.92%)
  used: 11.54 GiB (10.7%) fs: ext4 block-size: 4096 B
  dev: /dev/sdb2 maj-min: 8:18
  used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1
  maj-min: 8:17
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
  priority: -2 dev: /dev/sdb3 maj-min: 8:19
  System Temperatures: cpu: 74.0 C mobo: N/A
  Processes: 207 Uptime: 9h 4m wakeups: 5 Memory: 7.68 GiB
  used: 2.35 GiB (30.7%) Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 1229 lib: 329
  flatpak: 0 Shell: Bash (su) v: 5.1.8 running-in: konsole
  inxi: 3.3.06
And journalctl -b -p err:
-- Journal begins at Thu 2021-07-22 19:10:34 WEST, ends at Sat 2021->
Jul 24 08:52:08 macManjaro kernel: ACPI Error: Needed type [Referenc>
Jul 24 08:52:08 macManjaro kernel: ACPI Error: AE_AML_OPERAND_TYPE, >
Jul 24 08:52:08 macManjaro kernel: ACPI Error: Aborting method \_PR.>
Jul 24 10:04:08 macManjaro kernel: usb usb2-port3: Cannot enable. Ma>
Jul 24 10:04:11 macManjaro kernel: usb usb2-port3: Cannot enable. Ma>
Jul 24 10:04:34 macManjaro kernel: ERROR @wl_cfg80211_scan :
Jul 24 10:04:40 macManjaro wpa_supplicant[758]: bgscan simple: Faile>
Jul 24 13:47:01 macManjaro kernel: ERROR @wl_cfg80211_scan :
Jul 24 13:47:02 macManjaro kernel: ERROR @wl_cfg80211_scan :
Jul 24 13:47:08 macManjaro wpa_supplicant[758]: bgscan simple: Faile>
Jul 24 16:33:26 macManjaro kernel: ERROR @wl_cfg80211_scan :
Jul 24 16:33:27 macManjaro kernel: ERROR @wl_cfg80211_scan :
Jul 24 16:33:33 macManjaro wpa_supplicant[758]: bgscan simple: Faile>
Thanks for your attention.
Barrie
