Can’t say much without more info, but I have a ProArt X670E-CREATOR WIFI, and there was a bios update earlier this month, from the looks of it, all the X670E boards have this update, you may want to check, no idea if it might help you.
As a new forum user, it is encouraged to take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
I am guessing that your onboard wi-fi is Realtek or MediaTek, is that correct?
If that is so you should check with Linux Hardware Database - search for the ID provided from either lsusb or lspci depending on how it connects internally.
Prior to disabling MAC Randomization, it was doing this at random:
Nov 28 06:24:46 XXXX NetworkManager[921]: <info> [1732796686.2121] device (wlp13s0): set-hw-addr: set MAC address to B2:B2:BC:34:5F:C1 (scanning)
Nov 28 06:24:49 XXXX NetworkManager[921]: <info> [1732796689.0995] device (wlp13s0): set-hw-addr: reset MAC address to 4C:82:A9:40:FA:8D (preserve)
Nov 28 08:40:20 XXXX NetworkManager[921]: <info> [1732804820.9120] device (wlp13s0): set-hw-addr: set MAC address to 3E:F2:8B:A1:1F:FD (scanning)
Nov 28 08:40:21 XXXX NetworkManager[921]: <info> [1732804821.1847] device (wlp13s0): set-hw-addr: reset MAC address to 4C:82:A9:40:FA:8D (unmanage)
I checked the Install log and nothing was upgraded at the time this started. That got me thinking to check my router, and sure enough my Asus router (ZenWifi) got a firmware update, and the problem has been happening since then.
The fix was to turn off MAC Randomization in grub by creating:
/etc/NetworkManager/conf.d/wifi_rand_mac.conf
and including the following lines:
[device]
wifi.scan-rand-mac-address=no
Then update-grub and reboot
I think I’ll go back and test after the next firmware update.
