Updating to the latest Kernel 5.14, I was wondering if there is any reason to use a Real Time one. Other then for Music Applications I can’t think of any for most Users.
If you want to do real-times tasks, mainly used in industry (voip, image processing etc…)
From the Arch Wiki, I have no reasons to use such a Kernel.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or
if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
