With journalctl -b i got:
Okt 04 09:01:50 manjaro kernel: BTRFS info (device sda2): using crc32c (crc32c-x86) checksum algorithm
Okt 04 09:01:50 manjaro kernel: BTRFS warning (device sda2): space cache v1 is being deprecated and will be removed in a future release, please use -o space_cache=v2
That alone surprised me because I didn’t explicitly specify space cache v1
According to the documentation I’ve read so far, the btrfs utilities use spacecache=v2 by default since version 5.xxx.
But either that’s not correct, or it only applies to creating a new btrfs filesystem.
So I looked at the options in the fstab and added ,space_cache=v2. Nevertheless, v1 seems to still be used.
mount -t btrfs
/dev/sda2 on / type btrfs (rw,noatime,compress=zstd:9,ssd,discard=async,space_cache,subvolid=83648,subvol=/@)
cat /etc/fstab|grep 'subvol=@[^a-z]'
UUID=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx / btrfs rw,noatime,space_cache=v2,compress=zstd:9,subvol=@ 0 0
And now I have another warning from btrfs:
Okt 04 10:29:17 manjaro kernel: BTRFS info (device sda2): using crc32c (crc32c-x86) checksum algorithm
Okt 04 10:29:17 manjaro kernel: BTRFS warning (device sda2): space cache v1 is being deprecated and will be removed in a future release, please use -o space_cache=v2
Okt 04 10:29:17 manjaro kernel: BTRFS info (device sda2): enabling disk space caching
Okt 04 10:29:20 manjaro18 kernel: BTRFS warning (device sda2 state M): remount supports changing free space tree only from RO to RW
Apparently, “/” is mounted RO with the space_cache=v1 option. And that can’t be changed when remounting RW via the fstab later.
Yes, I ran mkinitcpio -P and rebooted.
What should I make of this?
