I have no idea why we need it, maybe even Firefox can be removed. I never used konversation and web-browser can also be more diverse as we can install our own preferrences by pacman or pamac.
Konversation is probably an oversight, as it was used to quickly connect to the Manjaro support IRC channel back in the day. But that no longer exists (I think).
A browser is pretty essential for any user, so Firefox should stay in my opinion.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
