Why does in my system top show 840MB of RAM used, but the “Task Manager” shows 1.2GIB?
Which shows correctly?
top
shows you how much RAM is used by the system itself, by applications, and by application data. However, the system will actually be using more RAM in the form of cache and buffers, both of which are a memory usage of a temporary nature, intended to increase performance — remember, unused RAM is useless RAM.
Both are correct, but you must read what each consider as “used”. It’s easier in top because it actually shows everything (they’re in man top result but here’s a simplictic explanation):
I don’t know what XFCE task manager considers as used, feel free to read its docs or even source code.
