Hi. After a system update last night, the global shortcuts seems to be broken. All the default shortcuts are not working. (e.g. ctrl alt T, ctrl F1/F2, alt tab…) When I check out the system setting menu, I got this… “Failed to Commuicate with Global Shortcuts Daemon”
Any help? Thanks
inxi --admin --verbosity=7 --filter --no-host
Summary
System: Kernel: 5.4.105-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=4a41d4da-2334-46a6-9fd6-b34364a2f498 rw quiet apparmor=1 security=apparmor
resume=UUID=cdad760d-7638-4e81-b62f-eff25c89221f udev.log_priority=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Desktop System: Gigabyte product: B250M-Gaming 3 v: N/A serial: <filter>
Mobo: Gigabyte model: B250M-Gaming 3-CF v: x.x serial: <filter> UEFI: American Megatrends
v: F5 date: 07/06/2017
Memory: RAM: total: 15.6 GiB used: 2.85 GiB (18.3%)
CPU: Info: Quad Core model: Intel Core i7-7700 bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 9E (158) stepping: 9 microcode: DE cache: L2: 8 MiB bogomips: 57616
Speed: 800 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800
6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1
bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht
hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP:
conditional, RSB filling
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 460.56
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: nvidia
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
s-diag: 554mm (21.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102 size: 476x268mm (18.7x10.6")
diag: 546mm (21.5")
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56 direct render: Yes
Audio: Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Sound Server-1: ALSA v: k5.4.105-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: yes
Network: Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: 3.2.6-k port: f000
bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Bluetooth: Message: No Bluetooth data was found.
Logical: Message: No LVM data was found.
RAID: Message: No RAID data was found.
Drives: Local Storage: total: 1.3 TiB used: 75.65 GiB (5.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 QVO 1TB size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: 1B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37120G size: 111.79 GiB
rev: 71E0 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HDP725025GLA380 size: 232.89 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s rotation: 7200 rpm
serial: <filter> rev: A52A scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Ultra Luxe size: 57.3 GiB
block-size: physical: 512 B logical: 512 B serial: <filter> rev: 1.00 scheme: MBR
Partition: ID-1: / raw-size: 102.69 GiB size: 100.58 GiB (97.94%) used: 75.63 GiB (75.2%) fs: ext4
dev: /dev/sdb2 maj-min: 8:18 label: N/A uuid: 4a41d4da-2334-46a6-9fd6-b34364a2f498
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 25.4 MiB (8.5%) fs: vfat
dev: /dev/sdb1 maj-min: 8:17 label: N/A uuid: C7F5-D33F
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb3
maj-min: 8:19 label: N/A uuid: cdad760d-7638-4e81-b62f-eff25c89221f
Unmounted: ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs label: N/A uuid: E22A98072A97D6BF
ID-2: /dev/sdc1 maj-min: 8:33 size: 549 MiB fs: ntfs
label: \xe7\xb3\xbb\xe7\xb5\xb1\xe4\xbf\x9d\xe7\x95\x99 uuid: 92C088D9C088C4C7
ID-3: /dev/sdc2 maj-min: 8:34 size: 231.79 GiB fs: ntfs label: HDD uuid: 2452FDC352FD99AE
ID-4: /dev/sdc3 maj-min: 8:35 size: 575 MiB fs: ntfs label: N/A uuid: 1A802755802736A3
ID-5: /dev/sdd1 maj-min: 8:49 size: 57.3 GiB fs: exfat label: hmwong uuid: FECB-623C
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
Device-1: 1-3:2 info: Razer USA DeathAdder Elite type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 1532:005c class-ID: 0300
Device-2: 1-4:3 info: Apple Aluminium Keyboard (ANSI) type: Keyboard,Mouse
driver: apple,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 05ac:024f
class-ID: 0301
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
Device-1: 2-2:2 info: SanDisk Ultra Luxe type: Mass Storage driver: usb-storage
interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 896mA chip-ID: 0781:55a3 class-ID: 0806
serial: <filter>
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 40 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 38%
Info: Processes: 230 Uptime: 41m wakeups: 0 Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: pacman: 1437 lib: 438 flatpak: 0 Shell: Bash v: 5.1.0
running-in: konsole inxi: 3.3.03
