Why do i randomly lose net connection?
Over night i lose sometimes my network connection and i would like to know why:
inxi -Fxzc0 tells:
        Generated on 2021-01-14 11:57:1610621833
#################### inxi -Fxzc0 ########################
System:    Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Xfce 4.14.3
           Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 81RS v: Lenovo Yoga S740-14IIL serial: <filter>
           Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO
           v: BYCN35WW date: 05/19/2020
Battery:   ID-1: BAT0 charge: 64.1 Wh condition: 65.3/62.0 Wh (105%) model: LGC L19L4PD2
           status: Unknown
CPU:       Info: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake rev: 5
           L2 cache: 8 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23968
           Speed: 1262 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1262 2: 1102 3: 1215
           4: 1254 5: 1258 6: 1249 7: 1213 8: 1250
Graphics:  Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel
           bus ID: 00:02.0
           Device-2: NVIDIA GP108M [GeForce MX250] vendor: Lenovo driver: nvidia v: 455.45.01
           bus ID: 2b:00.0
           Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 3-5:3
           Display: x11 server: X.Org 1.20.10 driver: modesetting,nvidia unloaded: intel,nouveau
           resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
           OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa 20.3.1
           direct render: Yes
Audio:     Device-1: Intel Smart Sound Audio vendor: Lenovo driver: sof-audio-pci bus ID: 00:1f.3
           Sound Server: ALSA v: k5.10.2-2-MANJARO
Network:   Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter driver: iwlwifi
           v: kernel port: 4000 bus ID: 00:14.3
           Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
           bus ID: 2-1.4:5
           IF: enp0s13f0u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
           IF-ID-1: pan1 state: down mac: <filter>
Drives:    Local Storage: total: 1.97 TiB used: 212.14 GiB (10.5%)
           ID-1: /dev/nvme0n1 vendor: Micron model: MTFDHBA1T0TCK size: 953.87 GiB temp: 38.9 C
           ID-2: /dev/sda type: USB vendor: JMicron Tech model: Generic size: 119.24 GiB
           ID-3: /dev/sdb type: USB vendor: Western Digital model: WD10EARX-00N0YB0
           ID-4: /dev/sdc type: USB vendor: Kingston model: DataTraveler 2.0 size: 14.54 GiB
Partition: ID-1: / size: 57.9 GiB used: 37.31 GiB (64.4%) fs: ext4 dev: /dev/nvme0n1p8
           ID-2: /boot/efi size: 259.5 MiB used: 85.8 MiB (33.1%) fs: vfat dev: /dev/nvme0n1p1
Swap:      ID-1: swap-1 type: partition size: 16.67 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p9
Sensors:   System Temperatures: cpu: 43.0 C mobo: N/A
Info:      Processes: 285 Uptime: 55m Memory: 15.2 GiB used: 2.31 GiB (15.2%) Init: systemd
           Compilers: gcc: 10.2.0 Packages: 1793 Client: Unknown Client: wrapper-2.0 inxi: 3.2.01
Hexchat stopped working last night at 23:19:00 so i filtered journalctl as:
journalctl --since="21-01-13  23:01:59" --until="21-01-13  23:59:59">>~/journalctl
        -- Journal begins at Sun 2021-01-10 18:57:54 CET, ends at Thu 2021-01-14 12:06:06 CET. --
Jan 13 23:02:13 manjaro CROND[277059]: (root) CMDOUT (run-parts: failed to exec /etc/cron.hourly/protokoll: Exec format error)
Jan 13 23:02:13 manjaro CROND[277059]: (root) CMDOUT (run-parts: /etc/cron.hourly/protokoll exited with return code 1)
Jan 13 23:16:43 manjaro kernel: usb 3-3.1.3: reset high-speed USB device number 8 using xhci_hcd
Jan 13 23:16:44 manjaro udisksd[1484]: Error performing housekeeping for drive /org/freedesktop/UDisks2/drives/WDC_WD10EARX_00N0YB0_WD_WMC0T0774640: Error updating SMART data: Error sending ATA command CHECK POWER MODE: Unexpected sense data returned:
                                       0000: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
                                       0010: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
                                        (g-io-error-quark, 0)
Jan 13 23:21:25 manjaro kernel: INFO: task kworker/2:1:276302 blocked for more than 122 seconds.
Jan 13 23:21:25 manjaro kernel:       Tainted: P        W  OE     5.10.2-2-MANJARO #1
Jan 13 23:21:25 manjaro kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan 13 23:21:25 manjaro kernel: task:kworker/2:1     state:D stack:    0 pid:276302 ppid:     2 flags:0x00004080
Jan 13 23:21:25 manjaro kernel: Workqueue: events rtl_work_func_t [r8152]
Jan 13 23:21:25 manjaro kernel: Call Trace:
Jan 13 23:21:25 manjaro kernel:  __schedule+0x295/0x810
Jan 13 23:21:25 manjaro kernel:  schedule+0x5b/0xc0
Jan 13 23:21:25 manjaro kernel:  rpm_resume+0x18c/0x810
Jan 13 23:21:25 manjaro kernel:  ? wait_woken+0x80/0x80
Jan 13 23:21:25 manjaro kernel:  rpm_resume+0x308/0x810
Jan 13 23:21:25 manjaro kernel:  __pm_runtime_resume+0x3b/0x60
Jan 13 23:21:25 manjaro kernel:  usb_autopm_get_interface+0x18/0x50
Jan 13 23:21:25 manjaro kernel:  rtl_work_func_t+0x69/0x2d0 [r8152]
Jan 13 23:21:25 manjaro kernel:  process_one_work+0x1d6/0x3a0
Jan 13 23:21:25 manjaro kernel:  worker_thread+0x4d/0x3d0
Jan 13 23:21:25 manjaro kernel:  ? rescuer_thread+0x410/0x410
Jan 13 23:21:25 manjaro kernel:  kthread+0x133/0x150
Jan 13 23:21:25 manjaro kernel:  ? __kthread_bind_mask+0x60/0x60
Jan 13 23:21:25 manjaro kernel:  ret_from_fork+0x1f/0x30
Jan 13 23:23:28 manjaro kernel: INFO: task DNS Res~ver #36:321709 blocked for more than 122 seconds.
Jan 13 23:23:28 manjaro kernel:       Tainted: P        W  OE     5.10.2-2-MANJARO #1
Jan 13 23:23:28 manjaro kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan 13 23:23:28 manjaro kernel: task:DNS Res~ver #36 state:D stack:    0 pid:321709 ppid:  1366 flags:0x00000080
Jan 13 23:23:28 manjaro kernel: Call Trace:
Jan 13 23:23:28 manjaro kernel:  __schedule+0x295/0x810
Jan 13 23:23:28 manjaro kernel:  schedule+0x5b/0xc0
Jan 13 23:23:28 manjaro kernel:  schedule_preempt_disabled+0x11/0x20
Jan 13 23:23:28 manjaro kernel:  __mutex_lock.constprop.0+0x17d/0x4f0
Jan 13 23:23:28 manjaro kernel:  ? update_load_avg+0x7e/0x630
Jan 13 23:23:28 manjaro kernel:  __netlink_dump_start+0xca/0x2d0
Jan 13 23:23:28 manjaro kernel:  ? rtnl_fill_link_ifmap+0x90/0x90
Jan 13 23:23:28 manjaro kernel:  rtnetlink_rcv_msg+0x287/0x390
Jan 13 23:23:28 manjaro kernel:  ? rtnl_calcit.isra.0+0x130/0x130
Jan 13 23:23:28 manjaro kernel:  netlink_rcv_skb+0x5b/0x100
Jan 13 23:23:28 manjaro kernel:  netlink_unicast+0x242/0x340
Jan 13 23:23:28 manjaro kernel:  netlink_sendmsg+0x243/0x480
Jan 13 23:23:28 manjaro kernel:  sock_sendmsg+0x5e/0x60
Jan 13 23:23:28 manjaro kernel:  __sys_sendto+0x120/0x180
Jan 13 23:23:28 manjaro kernel:  __x64_sys_sendto+0x25/0x30
Jan 13 23:23:28 manjaro kernel:  do_syscall_64+0x33/0x40
Jan 13 23:23:28 manjaro kernel:  entry_SYSCALL_64_after_hwframe+0x44/0xa9
Jan 13 23:23:28 manjaro kernel: RIP: 0033:0x7fa42ea278e4
Jan 13 23:23:28 manjaro kernel: RSP: 002b:00007fa40a9fd070 EFLAGS: 00000293 ORIG_RAX: 000000000000002c
Jan 13 23:23:28 manjaro kernel: RAX: ffffffffffffffda RBX: 00007fa40a9fe1a0 RCX: 00007fa42ea278e4
Jan 13 23:23:28 manjaro kernel: RDX: 0000000000000014 RSI: 00007fa40a9fe1a0 RDI: 000000000000003c
Jan 13 23:23:28 manjaro kernel: RBP: 0000000000000000 R08: 00007fa40a9fe144 R09: 000000000000000c
Jan 13 23:23:28 manjaro kernel: R10: 0000000000000000 R11: 0000000000000293 R12: 00007fa40a9fe144
Jan 13 23:23:28 manjaro kernel: R13: 00000000941bd779 R14: 000000000000003c R15: 0000000000000000
Jan 13 23:23:28 manjaro kernel: INFO: task ThreadPoolForeg:231681 blocked for more than 122 seconds.
Jan 13 23:23:28 manjaro kernel: task:ThreadPoolForeg state:D stack:    0 pid:231681 ppid: 46809 flags:0x00000080
Jan 13 23:23:28 manjaro kernel:  rpm_resume+0x18c/0x810
Jan 13 23:23:28 manjaro kernel:  ? wait_woken+0x80/0x80
Jan 13 23:23:28 manjaro kernel:  rpm_resume+0x308/0x810
Jan 13 23:23:28 manjaro kernel:  __pm_runtime_resume+0x3b/0x60
Jan 13 23:23:28 manjaro kernel:  usb_autopm_get_interface+0x18/0x50
Jan 13 23:23:28 manjaro kernel:  rtl8152_get_link_ksettings+0x27/0x80 [r8152]
Jan 13 23:23:28 manjaro kernel:  ethtool_get_settings+0xa7/0x1e0
Jan 13 23:23:28 manjaro kernel:  dev_ethtool+0x10fe/0x2ac0
Jan 13 23:23:28 manjaro kernel:  ? page_counter_try_charge+0x2f/0xb0
Jan 13 23:23:28 manjaro kernel:  ? __mod_memcg_lruvec_state+0x21/0xe0
Jan 13 23:23:28 manjaro kernel:  ? memcg_slab_post_alloc_hook+0x1b7/0x250
Jan 13 23:23:28 manjaro kernel:  ? inet6_ioctl+0xa9/0xf0
Jan 13 23:23:28 manjaro kernel:  ? netdev_name_node_lookup_rcu+0x68/0x80
Jan 13 23:23:28 manjaro kernel:  dev_ioctl+0x304/0x580
Jan 13 23:23:28 manjaro kernel:  sock_do_ioctl+0xe3/0x180
Jan 13 23:23:28 manjaro kernel:  sock_ioctl+0x272/0x3e0
Jan 13 23:23:28 manjaro kernel:  __x64_sys_ioctl+0x83/0xb0
Jan 13 23:23:28 manjaro kernel: RIP: 0033:0x7f5b57101f6b
Jan 13 23:23:28 manjaro kernel: RSP: 002b:00007f5b51702a38 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Jan 13 23:23:28 manjaro kernel: RAX: ffffffffffffffda RBX: 00007f5b51702b90 RCX: 00007f5b57101f6b
Jan 13 23:23:28 manjaro kernel: RDX: 00007f5b51702b90 RSI: 0000000000008946 RDI: 0000000000000028
Jan 13 23:23:28 manjaro kernel: RBP: 00007f5b51702c10 R08: 0000000000000001 R09: 0034753175306633
Jan 13 23:23:28 manjaro kernel: R10: 0000000000000021 R11: 0000000000000246 R12: 0000226e8d5e5f80
Jan 13 23:23:28 manjaro kernel: R13: 0000000000000028 R14: 000055b59d088a90 R15: 0000000000000000
Jan 13 23:23:28 manjaro kernel: INFO: task kworker/1:1:184248 blocked for more than 122 seconds.
Jan 13 23:23:28 manjaro kernel: task:kworker/1:1     state:D stack:    0 pid:184248 ppid:     2 flags:0x00004080
Jan 13 23:23:28 manjaro kernel: Workqueue: ipv6_addrconf addrconf_verify_work
Jan 13 23:23:28 manjaro kernel:  addrconf_verify_work+0xa/0x20
Jan 13 23:23:28 manjaro kernel:  process_one_work+0x1d6/0x3a0
Jan 13 23:23:28 manjaro kernel:  worker_thread+0x4d/0x3d0
Jan 13 23:23:28 manjaro kernel:  ? rescuer_thread+0x410/0x410
Jan 13 23:23:28 manjaro kernel:  kthread+0x133/0x150
Jan 13 23:23:28 manjaro kernel:  ? __kthread_bind_mask+0x60/0x60
Jan 13 23:23:28 manjaro kernel:  ret_from_fork+0x1f/0x30
Jan 13 23:23:28 manjaro kernel: INFO: task kworker/2:1:276302 blocked for more than 245 seconds.
Jan 13 23:23:28 manjaro kernel: task:kworker/2:1     state:D stack:    0 pid:276302 ppid:     2 flags:0x00004080
Jan 13 23:23:28 manjaro kernel: Workqueue: events rtl_work_func_t [r8152]
Jan 13 23:23:28 manjaro kernel:  rtl_work_func_t+0x69/0x2d0 [r8152]
Jan 13 23:23:28 manjaro kernel: INFO: task hexchat:321688 blocked for more than 122 seconds.
Jan 13 23:23:28 manjaro kernel: task:hexchat         state:D stack:    0 pid:321688 ppid:  1370 flags:0x00000080
Jan 13 23:23:28 manjaro kernel:  ? get_page_from_freelist+0x13f4/0x1cb0
Jan 13 23:23:28 manjaro kernel: RIP: 0033:0x7f96fca428e4
Jan 13 23:23:28 manjaro kernel: RSP: 002b:00007fff1363a020 EFLAGS: 00000293 ORIG_RAX: 000000000000002c
Jan 13 23:23:28 manjaro kernel: RAX: ffffffffffffffda RBX: 00007fff1363b150 RCX: 00007f96fca428e4
Jan 13 23:23:28 manjaro kernel: RDX: 0000000000000014 RSI: 00007fff1363b150 RDI: 000000000000000c
Jan 13 23:23:28 manjaro kernel: RBP: 0000000000000000 R08: 00007fff1363b0f4 R09: 000000000000000c
Jan 13 23:23:28 manjaro kernel: R10: 0000000000000000 R11: 0000000000000293 R12: 00007fff1363b0f4
Jan 13 23:23:28 manjaro kernel: R13: 000000000004e898 R14: 000000000000000c R15: 00007fff1363b938
Jan 13 23:23:28 manjaro kernel: INFO: task hexchat:321689 blocked for more than 122 seconds.
Jan 13 23:23:28 manjaro kernel: task:hexchat         state:D stack:    0 pid:321689 ppid:  1370 flags:0x00000080
Jan 13 23:23:28 manjaro kernel: RDX: 0000000000000014 RSI: 00007fff1363b150 RDI: 0000000000000013
Jan 13 23:23:28 manjaro kernel: R13: 000000000004e899 R14: 0000000000000013 R15: 00007fff1363b938
Jan 13 23:25:30 manjaro kernel: INFO: task NetworkManager:431 blocked for more than 122 seconds.
Jan 13 23:25:30 manjaro kernel:       Tainted: P        W  OE     5.10.2-2-MANJARO #1
Jan 13 23:25:30 manjaro kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Jan 13 23:25:30 manjaro kernel: task:NetworkManager  state:D stack:    0 pid:  431 ppid:     1 flags:0x00000080
Jan 13 23:25:30 manjaro kernel: Call Trace:
Jan 13 23:25:30 manjaro kernel:  __schedule+0x295/0x810
Jan 13 23:25:30 manjaro kernel:  schedule+0x5b/0xc0
Jan 13 23:25:30 manjaro kernel:  schedule_preempt_disabled+0x11/0x20
Jan 13 23:25:30 manjaro kernel:  __mutex_lock.constprop.0+0x17d/0x4f0
Jan 13 23:25:30 manjaro kernel:  ? security_capable+0x36/0x50
Jan 13 23:25:30 manjaro kernel:  rtnetlink_rcv_msg+0xf6/0x390
Jan 13 23:25:30 manjaro kernel:  ? rtnl_calcit.isra.0+0x130/0x130
Jan 13 23:25:30 manjaro kernel:  netlink_rcv_skb+0x5b/0x100
Jan 13 23:25:30 manjaro kernel:  netlink_unicast+0x242/0x340
Jan 13 23:25:30 manjaro kernel:  netlink_sendmsg+0x243/0x480
Jan 13 23:25:30 manjaro kernel:  sock_sendmsg+0x5e/0x60
Jan 13 23:25:30 manjaro kernel:  ____sys_sendmsg+0x25a/0x2a0
Jan 13 23:25:30 manjaro kernel:  ? copy_msghdr_from_user+0x6e/0xa0
Jan 13 23:25:30 manjaro kernel:  ___sys_sendmsg+0x97/0xe0
Jan 13 23:25:30 manjaro kernel:  __sys_sendmsg+0x81/0xd0
Jan 13 23:25:30 manjaro kernel:  do_syscall_64+0x33/0x40
Jan 13 23:25:30 manjaro kernel:  entry_SYSCALL_64_after_hwframe+0x44/0xa9
Jan 13 23:25:30 manjaro kernel: RIP: 0033:0x7f6668756ddd
Jan 13 23:25:30 manjaro kernel: RSP: 002b:00007ffc2b74f180 EFLAGS: 00000293 ORIG_RAX: 000000000000002e
Jan 13 23:25:30 manjaro kernel: RAX: ffffffffffffffda RBX: 00005651a0bb0030 RCX: 00007f6668756ddd
Jan 13 23:25:30 manjaro kernel: RDX: 0000000000000000 RSI: 00007ffc2b74f1c0 RDI: 000000000000000c
Jan 13 23:25:30 manjaro kernel: RBP: 0000000000000170 R08: 0000000000000000 R09: 0000000000000000
Jan 13 23:25:30 manjaro kernel: R10: 0000000000000008 R11: 0000000000000293 R12: 0000000000000000
Jan 13 23:25:30 manjaro kernel: R13: 00007ffc2b74f2f8 R14: 00007ffc2b74f2f4 R15: 0000000000000000
Jan 13 23:25:30 manjaro kernel: INFO: task DNS Res~ver #36:321709 blocked for more than 245 seconds.
Jan 13 23:25:30 manjaro kernel: task:DNS Res~ver #36 state:D stack:    0 pid:321709 ppid:  1366 flags:0x00000080
Jan 13 23:25:30 manjaro kernel:  ? update_load_avg+0x7e/0x630
Jan 13 23:25:30 manjaro kernel:  __netlink_dump_start+0xca/0x2d0
Jan 13 23:25:30 manjaro kernel:  ? rtnl_fill_link_ifmap+0x90/0x90
Jan 13 23:25:30 manjaro kernel:  rtnetlink_rcv_msg+0x287/0x390
Jan 13 23:25:30 manjaro kernel:  __sys_sendto+0x120/0x180
Jan 13 23:25:30 manjaro kernel:  __x64_sys_sendto+0x25/0x30
Jan 13 23:25:30 manjaro kernel: RIP: 0033:0x7fa42ea278e4
Jan 13 23:25:30 manjaro kernel: RSP: 002b:00007fa40a9fd070 EFLAGS: 00000293 ORIG_RAX: 000000000000002c
Jan 13 23:25:30 manjaro kernel: RAX: ffffffffffffffda RBX: 00007fa40a9fe1a0 RCX: 00007fa42ea278e4
Jan 13 23:25:30 manjaro kernel: RDX: 0000000000000014 RSI: 00007fa40a9fe1a0 RDI: 000000000000003c
Jan 13 23:25:30 manjaro kernel: RBP: 0000000000000000 R08: 00007fa40a9fe144 R09: 000000000000000c
Jan 13 23:25:30 manjaro kernel: R10: 0000000000000000 R11: 0000000000000293 R12: 00007fa40a9fe144
Jan 13 23:25:30 manjaro kernel: R13: 00000000941bd779 R14: 000000000000003c R15: 0000000000000000
Jan 13 23:25:30 manjaro kernel: INFO: task ThreadPoolForeg:184296 blocked for more than 122 seconds.
Jan 13 23:25:30 manjaro kernel: task:ThreadPoolForeg state:D stack:    0 pid:184296 ppid:  1245 flags:0x00000080
Jan 13 23:25:30 manjaro kernel: RIP: 0033:0x7ff5615c48e4
Jan 13 23:25:30 manjaro kernel: RSP: 002b:00007ff55e5d6920 EFLAGS: 00000293 ORIG_RAX: 000000000000002c
Jan 13 23:25:30 manjaro kernel: RAX: ffffffffffffffda RBX: 00007ff55e5d7a50 RCX: 00007ff5615c48e4
Jan 13 23:25:30 manjaro kernel: RDX: 0000000000000014 RSI: 00007ff55e5d7a50 RDI: 0000000000000025
Jan 13 23:25:30 manjaro kernel: RBP: 0000000000000000 R08: 00007ff55e5d79f4 R09: 000000000000000c
Jan 13 23:25:30 manjaro kernel: R10: 0000000000000000 R11: 0000000000000293 R12: 00007ff55e5d79f4
Jan 13 23:25:30 manjaro kernel: R13: 0000000088609512 R14: 0000000000000025 R15: 00007ff55e5d8120
Jan 13 23:46:51 manjaro systemd-timesyncd[409]: Timed out waiting for reply from 159.69.36.25:123 (2.arch.pool.ntp.org).
Jan 13 23:47:01 manjaro systemd-timesyncd[409]: Timed out waiting for reply from 85.236.36.4:123 (2.arch.pool.ntp.org).
Jan 13 23:47:12 manjaro systemd-timesyncd[409]: Timed out waiting for reply from 79.133.44.141:123 (2.arch.pool.ntp.org).
Jan 13 23:47:22 manjaro systemd-timesyncd[409]: Timed out waiting for reply from [2a03:4000:1e:c1::1]:123 (2.arch.pool.ntp.org).
Jan 13 23:47:32 manjaro systemd-timesyncd[409]: Timed out waiting for reply from [2a02:8106:19::4]:123 (2.arch.pool.ntp.org).
Jan 13 23:47:42 manjaro systemd-timesyncd[409]: Timed out waiting for reply from [2a01:7e01::f03c:91ff:fead:8320]:123 (2.arch.pool.ntp.org).
Jan 13 23:47:53 manjaro systemd-timesyncd[409]: Timed out waiting for reply from [2a00:f820:428::2]:123 (2.arch.pool.ntp.org).
Same period but additional “-u NetworkManager”
journalctl --since="21-01-13  23:01:59" --until="21-01-13  23:59:59" -u NetworkManager
-- Journal begins at Sun 2021-01-10 18:57:54 CET, ends at Thu 2021-01-14 12:16:06 CET. --
-- No entries --
Confused: NetworkManager has allready died?
Tipps are welcome!
How to paste text in </> if it containes empty rows?
See what I have changed to format it nicely. :crazy_face:
Thank you!
… have to try it in a new subject, because:
typing:
My _paste_here
did not work, same as using the butten </> above this edit field.
The answer is:
Howto paste multiple line text
Should be more present this very important hint!
Your HDD stopped responding for 2 minutes and kernel gave up. Everything what was waiting for IO has thrown error, including DNS resolver (Internet died), HexChat and other things.
Please share SMART data of your HDD.
Also perform SMART long-test and show us results.
Lastly please paste contents of /etc/cron.hourly/protokoll file.
long SMART test follows
smartctl --all /dev/nvme0n1
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.10.2-2-MANJARO] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number:                       Micron MTFDHBA1T0TCK
Serial Number:                      193823D7DB32
Firmware Version:                   002 P1LN
PCI Vendor/Subsystem ID:            0x1344
IEEE OUI Identifier:                0x00a075
Controller ID:                      0
Number of Namespaces:               1
Namespace 1 Size/Capacity:          1.024.209.543.168 [1,02 TB]
Namespace 1 Formatted LBA Size:     512
Namespace 1 IEEE EUI-64:            00a075 0123d7db32
Local Time is:                      Thu Jan 14 22:49:11 2021 CET
Firmware Updates (0x02):            1 Slot
Optional Admin Commands (0x0017):   Security Format Frmw_DL Self_Test
Optional NVM Commands (0x0017):     Comp Wr_Unc DS_Mngmt Sav/Sel_Feat
Maximum Data Transfer Size:         128 Pages
Warning  Comp. Temp. Threshold:     82 Celsius
Critical Comp. Temp. Threshold:     85 Celsius
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
 0 +     8.25W       -        -    0  0  0  0        0       0
 1 +     2.40W       -        -    1  1  1  1        0       0
 2 +     1.90W       -        -    2  2  2  2        0       0
 3 -   0.0800W       -        -    3  3  3  3    10000    2500
 4 -   0.0050W       -        -    4  4  4  4     5000   44000
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
 0 +     512       0         0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning:                   0x00
Temperature:                        39 Celsius
Available Spare:                    99%
Available Spare Threshold:          5%
Percentage Used:                    1%
Data Units Read:                    225.479 [115 GB]
Data Units Written:                 89.329 [45,7 GB]
Host Read Commands:                 3.537.295
Host Write Commands:                2.627.541
Controller Busy Time:               66
Power Cycles:                       216
Power On Hours:                     31
Unsafe Shutdowns:                   96
Media and Data Integrity Errors:    0
Error Information Log Entries:      0
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Temperature Sensor 1:               39 Celsius
Temperature Sensor 2:               41 Celsius
Error Information (NVMe Log 0x01, max 256 entries)
No Errors Logged
I check and log my download speed every hour and the result is in
2021-01-13 23:01:01  Online mit downloadrate von (14,9 MB/s)
2021-01-14 00:01:01  Offline
2021-01-14 01:01:01  Offline
2021-01-14 02:01:01  Offline
2021-01-14 03:01:01  Offline
2021-01-14 04:01:01  Offline
2021-01-14 05:01:02  Offline
2021-01-14 06:01:01  Offline
2021-01-14 07:01:01  Offline
2021-01-14 08:01:01  Offline
2021-01-14 09:01:01  Offline
2021-01-14 10:01:01  Offline
2021-01-14 12:01:01  Online mit downloadrate von (14,6 MB/s)
... und jetzt die gespeicherten records fĂĽr den Zeitraum: 2018-12-30 bis 2021-01-14
Uhrzeit 00 Anzahl 612 Summe downloadrate 8474431,52 Mittelwert der downloadrate 13,52 MB
Uhrzeit 01 Anzahl 621 Summe downloadrate 8551392,40 Mittelwert der downloadrate 13,45 MB
Uhrzeit 02 Anzahl 619 Summe downloadrate 8607383,08 Mittelwert der downloadrate 13,58 MB
Uhrzeit 03 Anzahl 622 Summe downloadrate 8639324,16 Mittelwert der downloadrate 13,56 MB
Uhrzeit 04 Anzahl 621 Summe downloadrate 8647352,32 Mittelwert der downloadrate 13,60 MB
Uhrzeit 05 Anzahl 619 Summe downloadrate 8598958,08 Mittelwert der downloadrate 13,57 MB
Uhrzeit 06 Anzahl 617 Summe downloadrate 8548577,28 Mittelwert der downloadrate 13,53 MB
Uhrzeit 07 Anzahl 618 Summe downloadrate 8619018,24 Mittelwert der downloadrate 13,62 MB
Uhrzeit 08 Anzahl 619 Summe downloadrate 8616171,52 Mittelwert der downloadrate 13,59 MB
Uhrzeit 09 Anzahl 619 Summe downloadrate 8576290,88 Mittelwert der downloadrate 13,53 MB
Uhrzeit 10 Anzahl 617 Summe downloadrate 8526431,08 Mittelwert der downloadrate 13,50 MB
Uhrzeit 11 Anzahl 618 Summe downloadrate 8559287,60 Mittelwert der downloadrate 13,53 MB
Uhrzeit 12 Anzahl 581 Summe downloadrate 8020665,24 Mittelwert der downloadrate 13,48 MB
Uhrzeit 13 Anzahl 595 Summe downloadrate 8259481,60 Mittelwert der downloadrate 13,56 MB
Uhrzeit 14 Anzahl 599 Summe downloadrate 8313543,12 Mittelwert der downloadrate 13,55 MB
Uhrzeit 15 Anzahl 601 Summe downloadrate 8353477,24 Mittelwert der downloadrate 13,57 MB
Uhrzeit 16 Anzahl 580 Summe downloadrate 8014193,60 Mittelwert der downloadrate 13,49 MB
Uhrzeit 17 Anzahl 564 Summe downloadrate 7891650,56 Mittelwert der downloadrate 13,66 MB
Uhrzeit 18 Anzahl 587 Summe downloadrate 8131915,28 Mittelwert der downloadrate 13,53 MB
Uhrzeit 19 Anzahl 593 Summe downloadrate 8183080,96 Mittelwert der downloadrate 13,48 MB
Uhrzeit 20 Anzahl 589 Summe downloadrate 8098923,56 Mittelwert der downloadrate 13,43 MB
Uhrzeit 21 Anzahl 589 Summe downloadrate 8099276,80 Mittelwert der downloadrate 13,43 MB
Uhrzeit 22 Anzahl 596 Summe downloadrate 8177920,00 Mittelwert der downloadrate 13,40 MB
Uhrzeit 23 Anzahl 613 Summe downloadrate 8502159,36 Mittelwert der downloadrate 13,54 MB
Mittelwert ueber alles: 13,53 MB
Anzahl Zeilen im Protokoll: 14795 davon ĂĽbersprungen: 286
Daten wurden ausgewertet ĂĽber einen Zeitraum vom : 2018-12-30 bis 2021-01-14 also 2 Jahr(e) und 0 Monat(e) und 15 Tag(e)
Here the smartctl long test result:
[manjaro cron.hourly]# smartctl --test=long /dev/nvme0n1
NVMe device successfully opened
Use 'smartctl -a' (or '-x') to print SMART (and more) information
[manjaro cron.hourly]# smartctl -x /dev/nvme0n1
Controller ID:                      0
Local Time is:                      Thu Jan 14 23:01:55 2021 CET
 0 +     512       0         0
Percentage Used:                    1%
Data Units Written:                 89.392 [45,7 GB]
Host Write Commands:                2.627.860
Power Cycles:                       216
Power On Hours:                     31
Temperature Sensor 2:               42 Celsius
No Errors Logged
So the Fix here would be: Replace HDD with SSD?
It’s the HDD, not SSD which stopped.
Please show stats for your WDC_WD10EARX, do long test on it as well.
When you do please show smartctl --all to show SMART attributes.
Data indicates that you have this hard drive on USB? It may prevent you from doing SMART tests. And having HDD on USB may decrease its stability as well, due to typical problems with USB dock cheap power wall adapters, for example (if you have any). Or it could be USB power saving options, and many other things.
Also, your system tries to execute text file /etc/cron.hourly/protokoll every hour and generates an error. Move this text file somewhere else.
A) cryptocurious, thanks a lot for your effort
B)… its 7 hours after midnight, i’m pensioner and still need sleep :slight_smile:
C) WDC_WD10EARX is my external backup drive, so no need to get to panic!!! Thats a good news!
D) The long test takes some time , i report later.
E) Question: i’m used to take Gnome-Drive to view and test SMART, but that does not show anything for my main internal SSD where my Manjaro is installed?! Or does a SSD does not have SMART features or has to be unmounted?
For the main SSD-drive with Manjaro I took extra installed smartctl that showed what i posted but the long test is much too quick?
F) As you can see … lots of things to learn!
G) A cron job “backintime” runs at 00:00 writing a Manjaro data backup to WDC_WD10EARX
“I’ll be back” … but first go to sleep again :slight_smile:
… enough sleep :slight_smile:
This could be the culpit:
External HD WDC_WD10EARX is connected over USB-C from my Laptop and this fu… is known for probs:
USB-C on Lenovo Yoga Laptop
Furthermore i queed several USB-hubs, ok no good idea!
So i think its ok to mark this thread as solved!
What i still have to investigate: gnome-disks doesn’t show me SMART values for my SSD’s. Smartctl shows smart-values but doesn not perform tests!
Glad we figured it out :slight_smile:
If Gnome Disks doesn’t show SMART data, then don’t use this tool. Smartctl have everything you need. Stats via --attributes or --all arguments, and tests via:
smartctl --test=long /dev/sda (Executes extended disk self-test)
Check smartctl --help for usage.
The drive has to be supported in the tool. In my case gnome gsmartcontrol reports a nvme drive as unsupported, are you using this tool? With smartctl installed inxi reports it as PASSED.
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO
SMART: yes health: PASSED
ID-2: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSA2CW080G3
SMART: yes state: enabled health: PASSED
What about standard USB 3 ports?
