Trying to install CBM using Pacman, get an error telling me target not found.
Why can I install this using apt but pacman is completely unable to find anything
(https:// aur.archlinux. org/packages/cbm)
Firstly, although pacman
works, it’s actually Arch Linux’ package management system, and not pamac
, which is Manjaro’s.
Secondly, it doesn’t look as if CBM is in the repositories, only the AUR:
$ pamac search cbm
qtcbm-git r132.55243bf-2 AUR
Qt GUI Frontend for the (Open)CBM utils
qtcbm 1.0.0-2 AUR
python2-pcbmode 4.9-1 AUR
circuit board design software with a twist
opencbm-git r1436.7134118b-1 AUR
OpenCBM allows access to Commodore (C64) storage devices VIC 1540, 1541, 1570, 1571, or even 1581 floppy drive
opencbm 0.4.99.99a-1 AUR
cbmem-git latest-1 AUR
A utility for reading from the CBMEM console on Coreboot systems
cbmconvert 2.1.4-1 AUR
Create, extract and convert 8-bit Commodore binary archives
cbmc-git 5.11.r1339.gabbb38942-1 AUR
Bounded Model Checking for ANSI-C
cbmc-bin 5.11-1 AUR
cbmc 5.11-1 AUR
cbmbasic-git 0.r17.89093eb-1 AUR
A 100% compatible version of Commodore's version of Microsoft BASIC 6502
cbm-git r19.a62ad24-1 AUR
Car Backdoor Maker : A hardware backdoor tool is presented having several advanced features
cbm 0.3.2-1 AUR
Color Bandwidth Meter - display in real time the network traffic speed
And pacman
doesn’t search the AUR, only install from it, manually. Whereas pamac
installs from the AUR.
So that’s probably what’s happening. So, to install CBM, run the following in a terminal:
pamac build cbm
Note pamac
and not pacman
That should work then.
Holy hell youre a saint, thank you so much
The Manjaro team did create pamac, but pacman works just as well.
The actual matter is that:
My bad. I thought I put this in there. I see now I didn’t.
