Here it is:
[ 8.718]
X.Org X Server 1.21.1.10
[ 8.718] Current Operating System: Linux pc 6.6.10-1-MANJARO #1 SMP PREEMPT_DYNAMIC Fri Jan 5 17:38:36 UTC 2024 x86_64
[ 8.718] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=[...] rw udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
[ 8.718]
[ 8.718] Current version of pixman: 0.43.0
[ 8.718] Before reporting problems, check http://wiki.x.org
[ 8.718] Markers: (--) probed, (**) from config file, (==) default setting,
[ 8.718] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Feb 9 22:52:01 2024
[ 8.721] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 8.721] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 8.722] (==) No Layout section. Using the first Screen section.
[ 8.722] (==) No screen section available. Using defaults.
[ 8.722] (**) |-->Screen "Default Screen Section" (0)
[ 8.722] (**) | |-->Monitor "<default monitor>"
[ 8.722] (==) No monitor specified for screen "Default Screen Section".
[ 8.722] (==) Automatically adding devices
[ 8.722] (==) Automatically enabling devices
[ 8.722] (==) Automatically adding GPU devices
[ 8.722] (==) Automatically binding GPU devices
[ 8.722] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 8.725] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 8.725] Entry deleted from font path.
[ 8.725] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 8.725] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 8.725] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/OTF
[ 8.725] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 8.725] (II) The server relies on udev to provide the list of input devices.
[ 8.725] (II) Module ABI versions:
[ 8.725] X.Org ANSI C Emulation: 0.4
[ 8.725] X.Org Video Driver: 25.2
[ 8.725] X.Org XInput driver : 24.4
[ 8.725] X.Org Server Extension : 10.0
[ 8.725] (++) using VT number 7
[ 8.725] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 8.726] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 8.726] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:09:00.0/0000:0a:00.0/0000:0b:00.0/drm/card1
[ 8.769] (--) PCI:*(11@0:0:0) 1002:731f:1458:2314 rev 196, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xfcb00000/524288, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[ 8.769] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 8.769] (II) LoadModule: "glx"
[ 8.770] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 8.776] (II) Module glx: vendor="X.Org Foundation"
[ 8.776] compiled for 1.21.1.10, module version = 1.0.0
[ 8.776] ABI class: X.Org Server Extension, version 10.0
[ 8.777] (==) Matched ati as autoconfigured driver 0
[ 8.777] (==) Matched modesetting as autoconfigured driver 1
[ 8.777] (==) Matched fbdev as autoconfigured driver 2
[ 8.777] (==) Matched vesa as autoconfigured driver 3
[ 8.777] (==) Assigned the driver to the xf86ConfigLayout
[ 8.777] (II) LoadModule: "ati"
[ 8.777] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 8.777] (EE) Failed to load /usr/lib/xorg/modules/drivers/ati_drv.so: /usr/lib/xorg/modules/drivers/ati_drv.so: file too short
[ 8.777] (EE) Failed to load module "ati" (loader failed, 0)
[ 8.777] (II) LoadModule: "modesetting"
[ 8.777] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 8.780] (II) Module modesetting: vendor="X.Org Foundation"
[ 8.780] compiled for 1.21.1.10, module version = 1.21.1
[ 8.780] Module class: X.Org Video Driver
[ 8.780] ABI class: X.Org Video Driver, version 25.2
[ 8.780] (II) LoadModule: "fbdev"
[ 8.780] (WW) Warning, couldn't open module fbdev
[ 8.780] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 8.780] (II) LoadModule: "vesa"
[ 8.780] (WW) Warning, couldn't open module vesa
[ 8.780] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 8.780] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 8.850] (II) modeset(0): using drv /dev/dri/card1
[ 8.851] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 8.851] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 8.851] (==) modeset(0): RGB weight 888
[ 8.851] (==) modeset(0): Default visual is TrueColor
[ 8.851] (II) Loading sub module "glamoregl"
[ 8.851] (II) LoadModule: "glamoregl"
[ 8.851] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 8.856] (II) Module glamoregl: vendor="X.Org Foundation"
[ 8.856] compiled for 1.21.1.10, module version = 1.0.1
[ 8.856] ABI class: X.Org ANSI C Emulation, version 0.4
[ 9.035] (II) modeset(0): glamor X acceleration enabled on AMD Radeon RX 5700 (radeonsi, navi10, LLVM 16.0.6, DRM 3.54, 6.6.10-1-MANJARO)
[ 9.035] (II) modeset(0): glamor initialized
[ 9.035] (==) modeset(0): VariableRefresh: disabled
[ 9.035] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 9.036] (II) modeset(0): Output DP-1 has no monitor section
[ 9.037] (II) modeset(0): Output DP-2 has no monitor section
[ 9.037] (II) modeset(0): Output DP-3 has no monitor section
[ 9.037] (II) modeset(0): Output HDMI-1 has no monitor section
[ 9.038] (II) modeset(0): EDID for output DP-1
[ 9.038] (II) modeset(0): Manufacturer: ACR Model: d2 Serial#: 50353323
[ 9.038] (II) modeset(0): Year: 2010 Week: 30
[ 9.038] (II) modeset(0): EDID Version: 1.3
[ 9.038] (II) modeset(0): Digital Display Input
[ 9.038] (II) modeset(0): Max Image Size [cm]: horiz.: 53 vert.: 29
[ 9.038] (II) modeset(0): Gamma: 2.20
[ 9.038] (II) modeset(0): DPMS capabilities: StandBy Suspend Off
[ 9.038] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 9.038] (II) modeset(0): First detailed timing is preferred mode
[ 9.038] (II) modeset(0): redX: 0.649 redY: 0.338 greenX: 0.289 greenY: 0.609
[ 9.038] (II) modeset(0): blueX: 0.146 blueY: 0.070 whiteX: 0.313 whiteY: 0.329
[ 9.038] (II) modeset(0): Supported established timings:
[ 9.038] (II) modeset(0): 720x400@70Hz
[ 9.038] (II) modeset(0): 640x480@60Hz
[ 9.038] (II) modeset(0): 640x480@67Hz
[ 9.038] (II) modeset(0): 800x600@56Hz
[ 9.038] (II) modeset(0): 800x600@60Hz
[ 9.038] (II) modeset(0): 1024x768@60Hz
[ 9.038] (II) modeset(0): 1024x768@70Hz
[ 9.038] (II) modeset(0): Manufacturer's mask: 0
[ 9.038] (II) modeset(0): Supported standard timings:
[ 9.038] (II) modeset(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 9.038] (II) modeset(0): #1: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 9.038] (II) modeset(0): #2: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 9.038] (II) modeset(0): #3: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 9.038] (II) modeset(0): #4: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 9.038] (II) modeset(0): Supported detailed timing:
[ 9.038] (II) modeset(0): clock: 148.5 MHz Image Size: 531 x 298 mm
[ 9.038] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 9.038] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 9.038] (II) modeset(0): Monitor name: B243H
[ 9.038] (II) modeset(0): Ranges: V min: 56 V max: 76 Hz, H min: 31 H max: 83 kHz, PixClock max 185 MHz
[ 9.038] (II) modeset(0): Serial No: LH30C03240L1
[ 9.038] (II) modeset(0): EDID (in hex):
[ 9.038] (II) modeset(0): 00ffffffffffff000472d200ab540003
[ 9.038] (II) modeset(0): 1e14010380351d78ea6085a6564a9c25
[ 9.038] (II) modeset(0): 125054b30c00714f81009500d1c08180
[ 9.038] (II) modeset(0): 010101010101023a801871382d40582c
[ 9.038] (II) modeset(0): 4500132a2100001a000000fc00423234
[ 9.038] (II) modeset(0): 33480a20202020202020000000fd0038
[ 9.038] (II) modeset(0): 4c1f5312000a202020202020000000ff
[ 9.038] (II) modeset(0): 004c4833304330333234304c310a00c7
[ 9.038] (II) modeset(0): Not using default mode "1440x810" (bad mode clock/interlace/doublescan)
[ 9.038] (II) modeset(0): Not using default mode "1600x900" (bad mode clock/interlace/doublescan)
[ 9.038] (II) modeset(0): Not using default mode "1920x1080" (bad mode clock/interlace/doublescan)
[ 9.038] (II) modeset(0): Printing probed modes for output DP-1
[ 9.038] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync -vsync (67.5 kHz eP)
[ 9.039] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 9.039] (II) modeset(0): EDID for output DP-2
[ 9.039] (II) modeset(0): Manufacturer: DEL Model: f011 Serial#: 808793676
[ 9.039] (II) modeset(0): Year: 2010 Week: 5
[ 9.039] (II) modeset(0): EDID Version: 1.3
[ 9.039] (II) modeset(0): Digital Display Input
[ 9.039] (II) modeset(0): Max Image Size [cm]: horiz.: 47 vert.: 30
[ 9.039] (II) modeset(0): Gamma: 2.20
[ 9.039] (II) modeset(0): DPMS capabilities: Off
[ 9.039] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 9.039] (II) modeset(0): Default color space is primary color space
[ 9.039] (II) modeset(0): First detailed timing is preferred mode
[ 9.039] (II) modeset(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[ 9.039] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.313 whiteY: 0.329
[ 9.039] (II) modeset(0): Supported established timings:
[ 9.039] (II) modeset(0): 720x400@70Hz
[ 9.039] (II) modeset(0): 640x480@60Hz
[ 9.039] (II) modeset(0): 640x480@75Hz
[ 9.039] (II) modeset(0): 800x600@60Hz
[ 9.039] (II) modeset(0): 800x600@75Hz
[ 9.039] (II) modeset(0): 1024x768@60Hz
[ 9.039] (II) modeset(0): 1024x768@75Hz
[ 9.039] (II) modeset(0): 1280x1024@75Hz
[ 9.039] (II) modeset(0): Manufacturer's mask: 0
[ 9.039] (II) modeset(0): Supported standard timings:
[ 9.039] (II) modeset(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 9.039] (II) modeset(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 9.039] (II) modeset(0): #2: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 9.039] (II) modeset(0): Supported detailed timing:
[ 9.039] (II) modeset(0): clock: 146.2 MHz Image Size: 474 x 296 mm
[ 9.039] (II) modeset(0): h_active: 1680 h_sync: 1784 h_sync_end 1960 h_blank_end 2240 h_border: 0
[ 9.039] (II) modeset(0): v_active: 1050 v_sync: 1053 v_sync_end 1059 v_blanking: 1089 v_border: 0
[ 9.039] (II) modeset(0): Serial No: H731H01S056L
[ 9.039] (II) modeset(0): Monitor name: DELL 2209WA
[ 9.039] (II) modeset(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 83 kHz, PixClock max 165 MHz
[ 9.039] (II) modeset(0): EDID (in hex):
[ 9.039] (II) modeset(0): 00ffffffffffff0010ac11f04c363530
[ 9.039] (II) modeset(0): 05140103802f1e782eee95a3544c9926
[ 9.039] (II) modeset(0): 0f5054a54b00714f8180b30001010101
[ 9.039] (II) modeset(0): 01010101010121399030621a274068b0
[ 9.039] (II) modeset(0): 3600da281100001c000000ff00483733
[ 9.039] (II) modeset(0): 31483031533035364c0a000000fc0044
[ 9.040] (II) modeset(0): 454c4c203232303957410a20000000fd
[ 9.040] (II) modeset(0): 00384b1e5310000a202020202020004c
[ 9.040] (II) modeset(0): Not using default mode "1024x768" (bad mode clock/interlace/doublescan)
[ 9.040] (II) modeset(0): Not using default mode "1440x810" (bad mode clock/interlace/doublescan)
[ 9.040] (II) modeset(0): Not using default mode "1600x900" (bad mode clock/interlace/doublescan)
[ 9.040] (II) modeset(0): Not using default mode "1280x800" (bad mode clock/interlace/doublescan)
[ 9.040] (II) modeset(0): Printing probed modes for output DP-2
[ 9.040] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz eP)
[ 9.040] (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 9.040] (II) modeset(0): EDID for output DP-3
[ 9.040] (II) modeset(0): EDID for output HDMI-1
[ 9.040] (II) modeset(0): Output DP-1 connected
[ 9.040] (II) modeset(0): Output DP-2 connected
[ 9.040] (II) modeset(0): Output DP-3 disconnected
[ 9.040] (II) modeset(0): Output HDMI-1 disconnected
[ 9.040] (II) modeset(0): Using spanning desktop for initial modes
[ 9.040] (II) modeset(0): Output DP-1 using initial mode 1920x1080 +0+0
[ 9.040] (II) modeset(0): Output DP-2 using initial mode 1680x1050 +1920+0
[ 9.040] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 9.040] (==) modeset(0): DPI set to (96, 96)
[ 9.040] (II) Loading sub module "fb"
[ 9.040] (II) LoadModule: "fb"
[ 9.040] (II) Module "fb" already built-in
[ 9.064] (==) modeset(0): Backing store enabled
[ 9.064] (==) modeset(0): Silken mouse enabled
[ 9.064] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 9.064] (==) modeset(0): DPMS enabled
[ 9.064] (II) modeset(0): [DRI2] Setup complete
[ 9.064] (II) modeset(0): [DRI2] DRI driver: radeonsi
[ 9.064] (II) modeset(0): [DRI2] VDPAU driver: radeonsi
[ 9.064] (II) Initializing extension Generic Event Extension
[ 9.064] (II) Initializing extension SHAPE
[ 9.065] (II) Initializing extension MIT-SHM
[ 9.065] (II) Initializing extension XInputExtension
[ 9.065] (II) Initializing extension XTEST
[ 9.065] (II) Initializing extension BIG-REQUESTS
[ 9.065] (II) Initializing extension SYNC
[ 9.065] (II) Initializing extension XKEYBOARD
[ 9.065] (II) Initializing extension XC-MISC
[ 9.065] (II) Initializing extension SECURITY
[ 9.065] (II) Initializing extension XFIXES
[ 9.065] (II) Initializing extension RENDER
[ 9.065] (II) Initializing extension RANDR
[ 9.065] (II) Initializing extension COMPOSITE
[ 9.065] (II) Initializing extension DAMAGE
[ 9.065] (II) Initializing extension MIT-SCREEN-SAVER
[ 9.065] (II) Initializing extension DOUBLE-BUFFER
[ 9.065] (II) Initializing extension RECORD
[ 9.066] (II) Initializing extension DPMS
[ 9.066] (II) Initializing extension Present
[ 9.066] (II) Initializing extension DRI3
[ 9.066] (II) Initializing extension X-Resource
[ 9.066] (II) Initializing extension XVideo
[ 9.066] (II) Initializing extension XVideo-MotionCompensation
[ 9.066] (II) Initializing extension GLX
[ 9.070] (II) AIGLX: Loaded and initialized radeonsi
[ 9.070] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 9.070] (II) Initializing extension XFree86-VidModeExtension
[ 9.070] (II) Initializing extension XFree86-DGA
[ 9.070] (II) Initializing extension XFree86-DRI
[ 9.070] (II) Initializing extension DRI2
[ 9.070] (II) modeset(0): Damage tracking initialized
[ 9.070] (II) modeset(0): Setting screen physical size to 952 x 285
[ 9.129] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 9.129] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 9.129] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 9.129] (**) Power Button: Applying InputClass "system-keyboard"
[ 9.129] (II) LoadModule: "libinput"
[ 9.129] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 9.132] (II) Module libinput: vendor="X.Org Foundation"
[ 9.132] compiled for 1.21.1.8, module version = 1.4.0
[ 9.132] Module class: X.Org XInput Driver
[ 9.132] ABI class: X.Org XInput driver, version 24.4
[ 9.132] (II) Using input driver 'libinput' for 'Power Button'
[ 9.132] (**) Power Button: always reports core events
[ 9.132] (**) Option "Device" "/dev/input/event1"
[ 9.137] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 9.137] (II) event1 - Power Button: device is a keyboard
[ 9.137] (II) event1 - Power Button: device removed
[ 9.186] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[a whole bunch of stuff regarding other devices]
[ 10.516] (II) modeset(0): Disabling kernel dirty updates, not required.
[ 15.438] (II) modeset(0): EDID vendor "DEL", prod id 61457
[ 15.438] (II) modeset(0): Using EDID range info for horizontal sync
[ 15.438] (II) modeset(0): Using EDID range info for vertical refresh
[ 15.438] (II) modeset(0): Printing DDC gathered Modelines:
[ 15.438] (II) modeset(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz eP)
[ 15.438] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 15.502] (II) modeset(0): Allocate new frame buffer 2970x1680 stride
[ 16.230] (II) modeset(0): EDID vendor "DEL", prod id 61457
[ 16.230] (II) modeset(0): Using hsync ranges from config file
[ 16.230] (II) modeset(0): Using vrefresh ranges from config file
[ 16.230] (II) modeset(0): Printing DDC gathered Modelines:
[ 16.230] (II) modeset(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz eP)
[ 16.230] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 16.230] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 16.230] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 16.230] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 16.230] (II) modeset(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 16.230] (II) modeset(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 16.230] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 16.230] (II) modeset(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 16.230] (II) modeset(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 16.230] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 120.328] (II) modeset(0): EDID vendor "DEL", prod id 61457
[ 120.328] (II) modeset(0): Using hsync ranges from config file
[ 120.328] (II) modeset(0): Using vrefresh ranges from config file
[ 120.328] (II) modeset(0): Printing DDC gathered Modelines:
[ 120.328] (II) modeset(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz eP)
[ 120.328] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
