After the code
package got it’s update of:
~/Desktop ······························································································································································································ 22:19:25
❯ cat /var/log/pacman.log | tail -n18
[2022-09-02T22:10:33+0300] [ALPM-SCRIPTLET] done
[2022-09-02T22:10:33+0300] [ALPM] transaction started
[2022-09-02T22:10:33+0300] [ALPM] installed electron19 (19.0.13-1)
[2022-09-02T22:10:34+0300] [ALPM] upgraded code (1.70.2-1 -> 1.71.0-1)
[2022-09-02T22:10:34+0300] [ALPM] upgraded python-setuptools (1:62.3.2-1 -> 1:62.3.3-1)
[2022-09-02T22:10:35+0300] [ALPM] transaction completed
[2022-09-02T22:10:35+0300] [ALPM] running '30-systemd-update.hook'...
[2022-09-02T22:10:35+0300] [ALPM] running '90-packagekit-refresh.hook'...
[2022-09-02T22:10:35+0300] [ALPM] running 'update-desktop-database.hook'...
[2022-09-02T22:11:35+0300] [PACMAN] Running 'pacman -Rns -'
[2022-09-02T22:11:39+0300] [ALPM] running 'texinfo-remove.hook'...
[2022-09-02T22:11:39+0300] [ALPM] transaction started
[2022-09-02T22:11:39+0300] [ALPM] removed liblouis (3.22.0-1)
[2022-09-02T22:11:39+0300] [ALPM] removed lib32-readline (8.1.002-1)
[2022-09-02T22:11:39+0300] [ALPM] transaction completed
[2022-09-02T22:11:39+0300] [ALPM] running '30-systemd-update.hook'...
[2022-09-02T22:11:39+0300] [ALPM] running '90-packagekit-refresh.hook'...
[2022-09-02T22:14:02+0300] [PAMAC] synchronizing package lists
I noticed that it switched to electron19:
❯ pacman -Qi electron19
Version : 19.0.13-1
Description : Build cross platform desktop apps with web technologies
Architecture : x86_64
URL : https://electronjs.org/
Licenses : MIT custom
Groups : None
Provides : None
Depends On : c-ares ffmpeg gtk3 libevent libxslt minizip nss re2 snappy
Optional Deps : kde-cli-tools: file deletion support (kioclient5) [installed]
libappindicator-gtk3: StatusNotifierItem support [installed]
pipewire: WebRTC desktop sharing under Wayland [installed]
trash-cli: file deletion support (trash-put)
xdg-utils: open URLs with desktop’s default (xdg-email, xdg-open) [installed]
Required By : code
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 179.13 MiB
Packager : Bruno Pagani <EDIT: removed>
Build Date : Sun 21 Aug 2022 11:38:30 MSK
Install Date : Fri 02 Sep 2022 22:10:33 MSK
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
❯ pacman -Qi code
Version : 1.71.0-1
Description : The Open Source build of Visual Studio Code (vscode) editor
URL : https://github.com/microsoft/vscode
Licenses : MIT
Groups : None
Provides : vscode
Depends On : electron19 libsecret libx11 libxkbfile ripgrep
Optional Deps : bash-completion: Bash completions [installed]
zsh-completions: ZSH completitons [installed]
x11-ssh-askpass: SSH authentication [installed]
Required By : None
Optional For : None
Replaces : None
Installed Size : 95.45 MiB
Packager : Massimiliano Torromeo <EDIT: removed>
Build Date : Fri 02 Sep 2022 01:30:28 MSK
Install Date : Fri 02 Sep 2022 22:10:34 MSK
Install Reason : Explicitly installed
Install Script : No
But the older electron18
does not have any package that could use it under the hood:
~/Desktop ······························································································································································································ 22:22:05
❯ pactree -r electron19
electron19
└─code
~/Desktop ······························································································································································································ 22:22:08
❯ pactree -r electron18
electron18
~/Desktop ······························································································································································································ 22:22:14
~/Desktop ······························································································································································································ 22:17:27
❯ pacman -Qi electron18
Version : 18.3.9-1
Groups : None
Provides : None
xdg-utils: open URLs with desktop's default (xdg-email, xdg-open) [installed]
Required By : None
Optional For : None
Replaces : None
Installed Size : 181.13 MiB
Build Date : Sun 21 Aug 2022 11:36:20 MSK
Install Date : Sun 21 Aug 2022 22:09:00 MSK
Install Script : No
But why the pacman
can’t find the package as garbage/orphan?
I tried:
❯ su
Password:
[pc Desktop]# pacman -Qtdq | pacman -Rns -
error: argument '-' specified with empty stdin
[pc Desktop]# pacman -Qqd | pacman -Rsu --print -
python-pyopenssl-22.0.0-1
python-markdown-3.4.1-1
python-fixtures-4.0.1-1
python-testtools-2.5.0-3
python-six-1.16.0-6
python-pbr-5.10.0-1
python-importlib-metadata-4.8.2-1
python-zipp-3.8.1-1
python-extras-1.0.0-10
python-cryptography-37.0.4-1
python-cffi-1.15.1-1
python-pycparser-2.21-3
python-ply-3.11-10
pulseaudio-rtp-16.1-1
pulseaudio-lirc-16.1-1
pulseaudio-jack-16.1-1
pipewire-media-session-docs-1:0.4.1-2
pigz-2.7-2
opera-ffmpeg-codecs-104.0.5112.102-1
lirc-1:0.10.1-12
libusb-compat-0.1.7-1
intellij-idea-ultimate-edition-jre-2022.2.1-1
gcc-12.2.0-1
libmpc-1.2.1-2
libisl-0.25-1
docker-scan-0.19.0-1
botan-2.19.2-1
bash-completion-2.11-2
[pc Desktop]#
About the pacman
~/Desktop ······························································································································································································ 22:23:53
❯ pacman -Qi pacman
Version : 6.0.1-12
Description : A library-based package manager with dependency support
URL : http://www.archlinux.org/pacman/
Licenses : GPL
Groups : base-devel
Provides : pacman-contrib pacman-init libalpm.so=13-64
Depends On : bash glibc libarchive curl gpgme gettext gawk coreutils gnupg grep fakeroot perl pacman-mirrors>=4.1.0
Optional Deps : perl-locale-gettext: translation support in makepkg-template
diffutils: for pacdiff [installed]
findutils: for pacdiff --find [installed]
mlocate: for pacdiff --locate
sudo: privilege elevation for several scripts [installed]
vim: default merge program for pacdiff
haveged: for pacman-init.service [installed]
Required By : appstream-glib archlinux-keyring base downgrade libpamac manjaro-keyring packagekit pkgfile yay
Optional For : None
Conflicts With : pacman-contrib pacman-init
Replaces : pacman-contrib pacman-init
Installed Size : 4.80 MiB
Packager : Mark Wagie <EDIT: removed>
Build Date : Wed 27 Jul 2022 17:18:10 MSK
Install Date : Wed 27 Jul 2022 23:43:27 MSK
Install Script : Yes
Thanks!
PS
I did the pamac update --force-refresh
and pacman -Syyuu
. It did not fix the problem.
PS2
I have the chaotic-aur
repo added (and have skypeforlinux-stable-bin
and perhaps something else from there) and also AUR turned on in pamac and have 3 packages installed from there (krusader-git
, icaclient
, opera-developer
