Hello,
I have had the minor issue of the first time one uses Steam’s OSK or uses the Steam controller configuration tool to input keyboard key after boot the system it will pop a permission window to allow it to input keyboard actions.
I have found an older post about it;
https://forum.manjaro.org/t/deactivate-remote-control-prompt-for-certain-applications/176603
But that uses the Flatpak version of steam while I use the Native version and thus doubt it will work.
Is there some way to whitelist Steam so that it (and preferably only it) is pre granted permission?
