Hello.
I have an issue where my whisker menu binding doesn’t work correctly.
If I press the super or alt+f1 key(s) to close the menu. It instantly pops back up. If I quickly press the button twice it will close. It sometimes will stop and work correctly, but when I go to use the computer next it returns.
Any suggestions? Thanks.
inxi
Kernel: 5.10.68-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=2a86e105-1e12-4ddb-9fb7-5d803efea2af rw quiet udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Laptop System: TOSHIBA product: Satellite L655 v: PSK2CU-0QU01U
serial: <filter>
Mobo: Intel model: N/A serial: <filter> BIOS: INSYDE v: 2.80
date: 07/03/2012
ID-1: BAT1 charge: 4.1 Wh (95.3%) condition: 4.3/4.2 Wh (101.9%) volts: 11.7
min: 11.7 model: LGC PA3817U-1BRS type: Li-ion serial: N/A
status: Discharging cycles: 1
RAM: total: 3.64 GiB used: 959.2 MiB (25.7%)
Info: Dual Core model: Intel Core i5 M 560 bits: 64 type: MT MCP
arch: Nehalem family: 6 model-id: 25 (37) stepping: 5 microcode: 7 cache:
L2: 3 MiB bogomips: 21285
Speed: 1197 MHz min/max: 1199/2667 MHz boost: enabled Core speeds (MHz):
1: 1197 2: 1197 3: 1197 4: 1197
Flags: acpi aes aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority
flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs pge pni popcnt pse
pse36 pti rdtscp rep_good sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
Type: l1tf
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Device-1: Intel Core Processor Integrated Graphics vendor: Toshiba
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
Device-2: Chicony CNF9055 Toshiba Webcam type: USB driver: uvcvideo
bus-ID: 2-1.1:3 chip-ID: 04f2:b1d6 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics (ILK) v: 2.1 Mesa 21.2.2
direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Toshiba
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
class-ID: 0403
Sound Server-1: ALSA v: k5.10.68-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: no
Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel port: 5000
bus-ID: 02:00.0 chip-ID: 8086:08b1 class-ID: 0280
Device-2: Qualcomm Atheros AR8152 v1.1 Fast Ethernet vendor: Toshiba
driver: atl1c v: kernel port: 2000 bus-ID: 03:00.0 chip-ID: 1969:2060
class-ID: 0200
bus-ID: 2-1.6:5 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 585 GiB used: 240.35 GiB (41.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: OCZ model: VERTEX4 size: 119.24 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD
serial: <filter> rev: 1.5 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HTS725050A9A364
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: C72E scheme: MBR
ID-1: / raw-size: 119.24 GiB size: 116.81 GiB (97.96%)
used: 39.69 GiB (34.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 2a86e105-1e12-4ddb-9fb7-5d803efea2af
ID-2: /mnt/Storage raw-size: 414.98 GiB size: 407.4 GiB (98.17%)
used: 200.67 GiB (49.3%) fs: ext4 dev: /dev/sdb4 maj-min: 8:20
label: Storage uuid: 3062e558-ecfc-419a-87d1-3289f9d1e4ce
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdb1 maj-min: 8:17 size: 50 MiB fs: ntfs label: System Reserved
uuid: 3A6E65AE6E65639B
ID-2: /dev/sdb2 maj-min: 8:18 size: 50.25 GiB fs: ntfs label: N/A
uuid: 121E913F1E911CB3
ID-3: /dev/sdb3 maj-min: 8:19 size: 498 MiB fs: ntfs label: N/A
uuid: E04CE5DD4CE5AE8A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.1:3 info: Chicony CNF9055 Toshiba Webcam type: Video
Device-2: 2-1.4:4 info: Realtek USB 2.0 multicard reader type: Mass Storage
driver: ums-realtek interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 0bda:0158 class-ID: 0806 serial: <filter>
Device-3: 2-1.6:5 info: Intel Bluetooth wireless interface type: Bluetooth
System Temperatures: cpu: 38.0 C mobo: N/A
Processes: 204 Uptime: 0m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1041 lib: 288 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.06
