Hello Community
After the last update i notice that in the whisker menu I can not select the 4 first programs popping up after a search with the Touch-pad are mouse. Also the sometime it’s just stay black are flickers in sector 1.
however in sector 2 and 3 there I can select the programs.
Inxi:
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=170e8758-ade9-4281-9a87-5c7f5317df71 rw
i915.enable_dpcd_backlight=0
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Dell product: XPS 15 9570 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0D0T05 v: A00 serial: <filter> UEFI: Dell v: 1.15.0
date: 12/25/2019
ID-1: BAT0 charge: 72.7 Wh condition: 72.7/97.0 Wh (75%) volts: 12.7/11.4
model: SMP DELL GPM0365 type: Li-ion serial: <filter> status: Full
Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE L2 cache: 9 MiB
bogomips: 52815
Speed: 1200 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 1200 2: 1200
3: 1200 4: 1200 5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 1200 11: 1200
12: 1200
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: nvidia
v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c8c
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-12:7 chip ID: 0c45:671d
Display: x11 server: X.Org 1.20.10 driver: nvidia
note: n/a (using device driver) display ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1102 s-dpi: 96 s-size: 1016x292mm (40.0x11.5")
s-diag: 1057mm (41.6")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Monitor-2: DP-3 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.1
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Sound Server: ALSA v: k5.10.2-2-MANJARO
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: 3000
bus ID: 3b:00.0 chip ID: 8086:2526
IF: wlp59s0 state: up mac: <filter>
Device-2: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
bus ID: 1-4:3 chip ID: 8087:0025
Local Storage: total: 1.88 TiB used: 1.42 TiB (75.5%)
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B2QEXM7
temp: 40.9 C
ID-2: /dev/sdb maj-min: 8:16 type: USB model: USB Flash Disk size: 58.05 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 1100
ID-1: / raw size: 1.82 TiB size: 1.79 TiB (98.38%) used: 1.4 TiB (78.4%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 3.91 GiB used: 3.5 MiB (0.1%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3199 fan-2: 3173
Processes: 408 Uptime: 2h 12m wakeups: 9235 Memory: 30.99 GiB
used: 8.19 GiB (26.4%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.0 Packages: 1787 pacman: 1766 lib: 457 flatpak: 17 snap: 4
Shell: Bash v: 5.1.0 running in: xfce4-terminal inxi: 3.2.01
