I haven’t ripped any CDs for a few months. Bought some a couple days ago, but I was greeted by this when I tried to rip them with whipper:
~ >>> whipper cd rip
INFO:whipper.command.cd:using configured read offset 6
INFO:whipper.command.cd:checking device /dev/sr0
WARNING:whipper.program.utils:command 'eject -t /dev/sr0' returned with exit code '1' (b'eject: CD-ROM tray close command failed: Input/output error')
CDDB disc id: 7b0bcb09
File "/usr/bin/whipper", line 33, in <module>
sys.exit(load_entry_point('whipper==0.10.0', 'console_scripts', 'whipper')())
File "/usr/lib/python3.9/site-packages/whipper/command/main.py", line 56, in main
ret = cmd.do()
File "/usr/lib/python3.9/site-packages/whipper/command/basecommand.py", line 141, in do
return self.cmd.do()
File "/usr/lib/python3.9/site-packages/whipper/command/cd.py", line 116, in do
self.mbdiscid = self.ittoc.getMusicBrainzDiscId()
File "/usr/lib/python3.9/site-packages/whipper/image/table.py", line 368, in getMusicBrainzDiscId
from discid import put
ModuleNotFoundError: No module named 'discid'
I have tried reinstalling whipper, twice.
System information
System: Kernel: 5.13.1-3-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=c28c9ba1-1ab9-48ed-a6c3-a5cf6794acea ro apparmor=1
security=apparmor udev.log_priority=3 sysrq_always_enabled=1
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop Mobo: Micro-Star model: B450M MORTAR MAX (MS-7B89) v: 1.0 serial: <filter>
UEFI: American Megatrends LLC. v: 2.D0 date: 05/17/2021
CPU: Info: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 8 stepping: 2
microcode: 800820D cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 118457
Speed: 2237 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz): 1: 2237 2: 2905 3: 2165 4: 2180 5: 2197
6: 2019 7: 3738 8: 2097 9: 2161 10: 2123 11: 2844 12: 2274 13: 2195 14: 2102 15: 3155 16: 2898
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: ASUSTeK driver: nvidia v: 470.42.01
alternate: nouveau,nvidia_drm bus-ID: 26:00.0 chip-ID: 10de:1b06 class-ID: 0300
Display: x11 server: X.Org 1.20.12 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.7x13.5") s-diag: 692mm (27.3")
Monitor-1: DP-0 res: 2560x1440 hz: 144 dpi: 109 size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 470.42.01 direct render: Yes
Audio: Device-1: NVIDIA GP102 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 26:00.1
chip-ID: 10de:10ef class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 28:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: GYROCOM C&C UAC1 DAC type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-10:2 chip-ID: 1852:5110
class-ID: 0102
Sound Server-1: ALSA v: k5.13.1-3-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
port: e000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
RAID: Supported mdraid levels: raid0
Device-1: md0 maj-min: 9:0 type: mdraid level: raid-0 status: active size: 744.74 GiB
Info: report: N/A blocks: 780914688 chunk-size: 512k super-blocks: 1.2
Components: Online:
0: sdb maj-min: 8:16 size: 186.31 GiB
1: sde maj-min: 8:64 size: 186.31 GiB
2: sdc maj-min: 8:32 size: 186.31 GiB
3: sdd maj-min: 8:48 size: 186.31 GiB
Drives: Local Storage: total: raw: 1.18 TiB usable: 1.18 TiB used: 552.73 GiB (45.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 model: SSD 910 200GB size: 186.31 GiB block-size: physical: 4096 B logical: 512 B
rotation: SSD serial: N/A rev: a424
ID-3: /dev/sdc maj-min: 8:32 model: SSD 910 200GB size: 186.31 GiB block-size: physical: 4096 B logical: 512 B
ID-4: /dev/sdd maj-min: 8:48 model: SSD 910 200GB size: 186.31 GiB block-size: physical: 4096 B logical: 512 B
ID-5: /dev/sde maj-min: 8:64 model: SSD 910 200GB size: 186.31 GiB block-size: physical: 4096 B logical: 512 B
Partition: ID-1: / raw-size: 465.26 GiB size: 456.96 GiB (98.22%) used: 193.11 GiB (42.3%) fs: ext4 dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 2 GiB used: 8.5 MiB (0.4%) priority: -2 file: /mnt/faaast/swap
Sensors: System Temperatures: cpu: 54.6 C mobo: 47.0 C gpu: nvidia temp: 53 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1356 fan-3: 1018 fan-4: 657 fan-5: 880 gpu: nvidia fan: 51%
Info: Processes: 343 Uptime: 3h 34m wakeups: 0 Memory: 31.28 GiB used: 4.48 GiB (14.3%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1355 lib: 406 Shell: Zsh v: 5.8 running-in: yakuake
inxi: 3.3.04
