I have a laptop with a Celeron N4020, 4GB RAM and a 2560x1600 display (an Adreamer Leobook 13, for anyone interested). I normally use Windows (although I do use some Linux machines at work and have toyed with Linux over the years), so don’t have lots of experience with desktop Linux variants, but after some research I chose Manjaro Xfce on the assumption that it would be a good choice for the entry level hardware.
It indeed is a lot more responsive than Windows and although it has its share of small issues (which I’ll ask about later if I continue to use it) it feels like something I could get used to.
The problem I want to ask about first is UI scaling. The 2560x1600 13.3" display is very sharp, and text is very small if used at 1:1. Windows allows scaling the UI to x1.25 or x1.50, which is more comfortable.
In Xfce though I only see a x2 option, which is too big, and the scaling doesn’t affect Falkon, which I installed as a browser because I’ve read it’s the most lightweight, and it includes the functionality I want (which is mostly a vertical tab tree). (I also installed Brave so I could watch Netflix.)
Another alternative is display scaling, which, when set to 0.7, produces something that I find usable, even if it doesn’t look as good as UI scaling. The problem is that I tried installing and running a game (Legend of Grimrock), and it showed only a partial screen, and it took me a while to realise that it must be because of the scaling.
I could have worked with it if I was able to set different scaling to different workspaces, but I don’t think that’s a thing.
So I’m assuming that if I want usable scaling, I will have to use another desktop. (That’s assuming that usable scaling exists in another Linux desktop.) The question is then: is there a Manjaro version with a desktop that supports good fractional scaling (if it works on Falkon all the better) and would perform decently well on the slow hardware?
I got stuck at the Window Manager step. It says to do things under the Style tab, but there’s no such tab. The tabs available are: Cycling, Focus, Accessibility, Workspaces, Placement and Compositor.
Edit: I will continue with trying to install a theme and tweak other stuff.
It has but in my experience Plasma needs decent graphics. This is an ultra-low-power Celeron 4020 with a TDP of 6W and an Intel UHD 600 that takes its memory from the already tight 4GB of ram (although upgrade to 8GB might be poss) running already a fairly high-res display, I doubt this will work smoothly.
Thanks for the link to the LXQt spin. I agree, a low resource desktop is a great way to go. LXQt needs just 600mb of ram for the desktop. The CPU of the op only has 2 cores, no hyper threading, and a top speed of 2.8 ghz. I use the LXQt spin as my desktop, and I have a 13 year old CPU. It works fine. My wife has it on a athlon x2 5600 (2.8 ghz) and it works ok. Mabox is another great choice.
XFCE 4.20 has support for fractional scaling of display - xfce4-display-settings – Scale;
and fonts - xfce4-appearance-settings > Fonts – Custom DPI Settings
