Do have an order to rewrite fastab?
I don’t know if I knocked Grab commands or mkninitcpio -P command my fstab was reset rewritten
Nothing rewrites fstab unconditionally.
You will have to retrace your steps - e.g. using the history command
history
Even be via Liveusb to repair
Even then …
If the partition is changed and reformat, should i manually change the UUIDs fstab?
That may be necessary …
