As the title says, i would like to find the changelog of Linux Kernel patch versions (preferably with the Manjaro config and not just the C code, but a summary - i dont quite understand C/C++ code) or to know a way to better debug the issue below.
I would like to know the changes between kernel 5.15.2 and 5.15.6, because when upgrading to 5.15.6, using sudo tlp bat
does not make the fans quieter anymore (i cant control the fans otherwise because its a laptop, see below for more information on why).
Extra Notes:
System Information (using the 5.15.2 kernel)
$ inxi -b
Host: pina Kernel: 5.15.2-2-MANJARO x86_64 bits: 64
Desktop: KDE Plasma 5.23.4 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: TUF Gaming FA706IU_FA706IU v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: FA706IU v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FA706IU.309 date: 07/02/2020
ID-1: BAT1 charge: 43.3 Wh (100.0%) condition: 43.3/48.2 Wh (89.8%)
volts: 3.8 min: 11.9
Info: 8-core AMD Ryzen 9 4900H with Radeon Graphics [MT MCP] speed (MHz):
avg: 1396 min/max: 1400/3300
Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] driver: N/A
Device-2: AMD Renoir driver: amdgpu v: kernel
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
Display: wayland server: X.Org 1.21.1.3 driver: loaded: amdgpu,ati
unloaded: modesetting resolution: 1920x1080~60Hz
driver: r8169
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8822ce
Local Storage: total: 476.94 GiB used: 61.49 GiB (12.9%)
Processes: 409 Uptime: 18h 17m Memory: 15.12 GiB used: 2.89 GiB (19.1%)
Shell: Zsh inxi: 3.3.10
$ uname -a
Linux pina 5.15.2-2-MANJARO #1 SMP PREEMPT Sat Nov 13 19:25:38 UTC 2021 x86_64 GNU/Linux
tlp config:
# I Removed the commented out values to not spam the thread
CPU_SCALING_GOVERNOR_ON_BAT="powersave"
CPU_BOOST_ON_AC="1"
CPU_BOOST_ON_BAT="0"
PLATFORM_PROFILE_ON_AC="balanced"
PLATFORM_PROFILE_ON_BAT="quiet"
RADEON_DPM_PERF_LEVEL_ON_BAT="low"
RADEON_DPM_STATE_ON_AC="performance"
RADEON_DPM_STATE_ON_BAT="battery"
RADEON_POWER_PROFILE_ON_AC="auto"
RADEON_POWER_PROFILE_ON_BAT="low"
USB_EXCLUDE_PRINTER="0"
DEVICES_TO_DISABLE_ON_STARTUP="bluetooth"
Laptop: ASUS TUF FA706IU (if i got the right value)
This Laptop’s only “advertised” way to control the fans is with asus-nb-wmi
's fan_boost_mode
, but changing this does nothing on my device, i also tried setting /sys/firmware/acpi/platform_profile
to quiet
(which is listed in platfrom_profile_choices
(The fans cannot be controlled in the BIOS / UEFI interface)
I had also tried applying tlp options manually, but doing them one by one (reading value, setting to wanted value, then testing, then back to default for next value), which did not change the behavior, so my only way to get the fans quiet is to use sudo tlp bat
to force all the options.
The Nvidia GPU is listed as Off
in nvidia-smi
and i basically dont use it.
If more information is needed, please ask i will try to provide
For now i have installed the linux515-5.15.2-2-x86_64.pkg.tar.zst
from the pacman cache as a temporary fix
