Hi everybody,
After the last update, Firefox is freezing the entire system for two seconds (cant move mouse, for example) at random (every 10 minutes?). I believe this does not happen when using Wayland (and with firefox in wayland mode).
I have already done Firefox hangs at random times, including disabling hardware acceleration, with no avail.
System info:
inxi -v7azy
Kernel: 6.4.2-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.4-x86_64
root=UUID=5a5f4668-c53b-4483-a3bd-ddedeaac4a3d rw rootflags=subvol=@ quiet
splash resume=UUID=1dd51082-ec51-4a48-8f5b-921905e8a0ef
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: LENOVO product: 82JU v: Legion 5 15ACH6H
serial: <superuser required> Chassis: type: 10 v: Legion 5 15ACH6H
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: GKCN57WW date: 06/16/2022
ID-1: BAT0 charge: 58.1 Wh (97.0%) condition: 59.9/60.0 Wh (99.8%)
volts: 16.9 min: 15.4 model: Sunwoda L20D4PC0 type: Li-poly serial: <filter>
status: not charging cycles: 36
Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 16 GiB note: est. available: 13.51 GiB
used: 3.12 GiB (23.1%)
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 2589 high: 4442 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3552 2: 3552
3: 1200 4: 3200 5: 3551 6: 1200 7: 3550 8: 3200 9: 1200 10: 3550 11: 1200
12: 1200 13: 4438 14: 4442 15: 1200 16: 1200 bogomips: 102241
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,eDP-2 bus-ID: 01:00.0 chip-ID: 10de:2560 class-ID: 0300
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none off: eDP-1 empty: none
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 44.0 C
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: radeonsi
gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: primary
model: HP N246v serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 92
gamma: 1.2 size: 528x297mm (20.79x11.69") diag: 606mm (23.9") ratio: 16:9
modes: max: 1920x1080 min: 640x480
Monitor-2: eDP-1 note: disabled model: AU Optronics 0xb69b built: 2021
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.4.2-3-MANJARO) direct-render: Yes
Device-1: NVIDIA GA106 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.4.2-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8852 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:4852
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 408.96 GiB (85.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPMPZ-512G-1101 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 21160001 temp: 43.9 C scheme: GPT
ID-1: / raw-size: 461.78 GiB size: 461.78 GiB (100.00%)
used: 408.7 GiB (88.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 5a5f4668-c53b-4483-a3bd-ddedeaac4a3d
used: 3.9 MiB (1.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 72D4-F1BE
ID-3: /home raw-size: 461.78 GiB size: 461.78 GiB (100.00%)
ID-4: /var/cache raw-size: 461.78 GiB size: 461.78 GiB (100.00%)
ID-5: /var/log raw-size: 461.78 GiB size: 461.78 GiB (100.00%)
ID-1: swap-1 type: partition size: 14.86 GiB used: 264.8 MiB (1.7%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 1dd51082-ec51-4a48-8f5b-921905e8a0ef
Hub-2: 1-2:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 1-4:3 info: Integrated Express ITE Device(8910) type: keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c101 class-ID: 0301
Hub-3: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-4: 2-2:2 info: Realtek Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: Logitech USB Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c53f class-ID: 0300
Device-2: 3-4:3 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 65.5 C mobo: N/A gpu: amdgpu temp: 44.0 C
Processes: 360 Uptime: 2m wakeups: 3 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 alt: 12 clang: 15.0.7 Packages: 1550
pm: pacman pkgs: 1543 libs: 476 tools: pamac pm: flatpak pkgs: 7 Shell: Zsh
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
Thanks in advance!
