After 10 minutes the computer goes to suspend to disc.
Then the resume does not work, the computer freezes and I must press the reset button.
inxi -Fza:
Kernel: 6.1.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.1-x86_64
root=UUID=ea34cc1e-e69b-4519-bb9a-dfb3ec61db74 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Server System: Supermicro product: X10SRA v: 0123456789
serial: <filter> Chassis: type: 17 v: 0123456789 serial: <filter>
Mobo: Supermicro model: X10SRA v: 1.01 serial: <filter>
UEFI: American Megatrends v: 2.1a date: 10/24/2018
Info: model: Intel Core i7-6800K socket: LGA2011-3 bits: 64 type: MT MCP
arch: Broadwell gen: core 6 level: v3 note: check built: 2015-18
process: Intel 14nm family: 6 model-id: 0x4F (79) stepping: 1
microcode: 0xB000040
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 15 MiB desc: 1x15 MiB
Speed (MHz): avg: 1200 min/max: 1200/3800 base/boost: 3400/4000 scaling:
driver: intel_cpufreq governor: schedutil volts: 1.8 V ext-clock: 100 MHz
cores: 1: 1200 2: 1200 3: 1200 4: 1200 5: 1200 6: 1200 7: 1200 8: 1200
9: 1200 10: 1200 11: 1200 12: 1200 bogomips: 81634
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] driver: nouveau v: kernel
non-free: 535.xx+ status: current (as of 2023-08) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: DP-1
empty: DVI-D-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 10de:2182 class-ID: 0300
temp: 28.0 C
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: nouveau gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58") monitors: <missing: xrandr>
Monitor-1: DP-1 model: Dell U2713HM serial: <filter> built: 2012
res: 2560x1440 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
API: OpenGL v: 4.3 Mesa 23.1.6-2 renderer: NV168 direct-render: Yes
Device-1: Intel C610/X99 series HD Audio vendor: Super Micro
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20
class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 03:00.1 chip-ID: 10de:1aeb class-ID: 0403
API: ALSA v: k6.1.49-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.78 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
Device-1: Intel I210 Gigabit Network vendor: Super Micro driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0
chip-ID: 8086:1533 class-ID: 0200
Device-2: Intel I210 Gigabit Network vendor: Super Micro driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 06:00.0
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.38 TiB used: 268.11 GiB (19.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 23.9 C
scheme: GPT
SMART: yes health: PASSED on: 31d 18h cycles: 8,322
read-units: 67,169,582 [34.3 TB] written-units: 18,999,673 [9.72 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 512GB
family: based SSDs size: 476.94 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 4B6Q temp: 22 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 112d 1h cycles: 29123
written: 6.93 TiB
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 8.9 GiB (9.1%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%)
used: 150 MiB (15.4%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6
ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 292 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-4: /home raw-size: 300 GiB size: 294.23 GiB (98.08%)
used: 10.42 GiB (3.5%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p9
maj-min: 259:9
ID-5: /var raw-size: 32.46 GiB size: 31.66 GiB (97.51%)
used: 6.08 GiB (19.2%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p10
maj-min: 259:10
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 18.0 C pch: 31.5 C mobo: N/A gpu: nouveau
temp: 28.0 C
Fan Speeds (rpm): N/A gpu: nouveau fan: 429
Processes: 286 Uptime: 4m wakeups: 0 Memory: total: 32 GiB
available: 31.23 GiB used: 2.29 GiB (7.3%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1219 libs: 372 tools: pamac pm: flatpak pkgs: 0
Shell: Bash (su) v: 5.1.16 running-in: konsole inxi: 3.3.29
