I type Gammy in add/remove software, but get nothing. I want a GUI tool to adjust Gamma, I know one is out there.
Moderator edit: Use proper nouns and adjectives, not “this” or post videos
It is available from the AUR. Install via Pamac GUI or in terminal
https://aur.archlinux.org/packages/gammy
pamac build gammy
I really wonder why you ask instead of first trying to look for yourself.
If it is in the AUR, you have to have enabled this feature in pamac (which is: add/remove software)
before you can even see it or use it from there.
Get to know the system you are using (trying to use).
Thanks, it is stable right?
The upstream URL leads to page being blocked by uBlock Origin.
Ah, hadn’t noticed that. I guess the developer stopped paying for the domain and a cyber squatter bought it.
I also hadn’t noticed the upstream repo is archived.
This project is not being worked on anymore. A new, linux-only version is being developed here.
FYI, both the gammy
and gammy-git
AUR package will be deleted soon. Use gummy
or gummy-git
instead.
Well crap, that is why I don’t see it after I enabled AUR support.
