Where can I find an extension or plugin allowing me to have my public IP address displayed at the top right of my screen?
Hi all,
I am on Manjaro GNOME and I would like to know, where can I find an extension, or, a plugin, allowing me to have my public IP address displayed at the top right of my screen.
I know it exists, because I saw someone under Manjaro have it, but, I don't know what it's called ... Someone can guide me?
Here is where the plugin is supposed to find ... : https://i.imgur.com/2AB6MsV.png
There is the pubip AUR package that you might try in conjunction with conky to display it and run it in a set interval.
https://extensions.gnome.org/
loads here
Thanks ! I've download it, how can I activate it now ? :slight_smile:
in extenstions
Mod key (windows) bring search up .. type in " Extenstions"
I'm realy nooby... I can't find it :confused: https://i.imgur.com/kOUNkWR.png
did u install
that just one of many .. pick the one you want
I've this : https://i.imgur.com/nCMDu3M.png
And this : https://i.imgur.com/ABOFcG4.png
But I don't know how can I run it
The solution i posted was system agnostic i.e. meaning it should work on any DE.
While the solution @shjim posted was specific to Gnome and would probably be easier.
if you not sure about AUR .. pls save yourself pain and stay away from it until you know a little more .. gnome extenstion may be better for U..
I have installed all extension means "public ip" but i don't found in extensions...
I have already install packages from AUR :slight_smile: it's fine
some extenstions need logout and some dont . in my xp
Maybe... Because i've installed it, i'm sure, but unable to find...
https://i.imgur.com/hsDlJ5a.png It's work !! Thanks to all :slight_smile:
Congrats. Now mark the post that gave you the solution as solution and you had your first successful thread that might help others in the future.
No Problem :slight_smile:
