I was trying to use 2 more monitors in addition to that of my laptop, but when my HDMI monitor is turned on my VGA monitor it becomes black and is no longer recognized, and vice versa
Welcome to Manjaro!
- Please read this:
[HowTo] Provide System Information
and press the three dots … below your post and press theto give us more information so we can see what’s really going on.
Now we know the symptom of the disease, but we need some more probing to know where the origin lies… - An
would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=e3c4e87f-b63b-409c-8335-70f0220ce027 rw quiet
udev.log_priority=3
Desktop: GNOME v: 41.5 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Laptop System: Acer product: TravelMate P215-41 v: V2.00
serial: <superuser required>
Mobo: RO model: Bassdrum_RC v: V2.00 serial: <superuser required>
UEFI: INSYDE v: 2.00 date: 05/25/2021
ID-1: BAT1 charge: 53.0 Wh (100.0%) condition: 53.0/53.2 Wh (99.5%)
volts: 13.1 min: 11.6 model: COSMX AP20CBL type: Li-ion serial: <filter>
status: full
RAM: total: 7.2 GiB used: 3.28 GiB (45.5%)
RAM Report:
Info: model: AMD Ryzen 5 PRO 4650U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1457 high: 2131 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1396
3: 1397 4: 1397 5: 1397 6: 2131 7: 1397 8: 1396 9: 1397 10: 1397 11: 1397
12: 1396 bogomips: 50322
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Device-1: AMD Renoir vendor: Acer Incorporated ALI driver: amdgpu v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: DP-1,eDP-1 empty: DP-2 bus-ID: 05:00.0 chip-ID: 1002:1636
class-ID: 0300
Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-3:3
chip-ID: 0408:a061 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: LG (GoldStar) TV serial: <filter> built: 2015
res: 1920x1080 dpi: 30 gamma: 1.2 size: 160x90mm (6.3x3.54")
diag: 1836mm (72.3") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 model: LG Display 0x0563 built: 2017 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.32-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.8 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: no
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
IP v6: <filter> type: noprefixroute scope: global
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
Local Storage: total: 238.47 GiB used: 10.89 GiB (4.6%)
model: PC SN530 SDBPNPZ-256G-1114 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21113000 temp: 29.9 C scheme: GPT
ID-1: / raw-size: 145.99 GiB size: 142.64 GiB (97.71%)
used: 10.84 GiB (7.6%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: e3c4e87f-b63b-409c-8335-70f0220ce027
used: 50.9 MiB (53.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: ESP uuid: 1E8E-39D0
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 91.37 GiB fs: ntfs label: Acer
uuid: 58AC8F2CAC8F03AA
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1024 MiB fs: ntfs
label: Recovery uuid: AA149016148FE3A3
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-2:2 info: Logitech G402 Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c07e class-ID: 0300 serial: <filter>
Device-2: 1-3:3 info: Quanta HD User Facing type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:a061
class-ID: 0e02
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Chicony Asus Keyboard type: Keyboard,HID
driver: asus,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s power: 100mA
chip-ID: 04f2:1125 class-ID: 0300
Device-2: 3-3:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
Processes: 326 Uptime: 36m wakeups: 223 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 875 lib: 264
Shell: Zsh v: 5.8.1 running-in: gnome-terminal inxi: 3.3.15```
Switch back to Xorg at the login screen (botom right).
xorg is not displayed
Could it be that your GPU only supports two display? (Mine does, so I know that’s a possibility.)
click on the user account, then the button should be displayed.
it doesn’t
i hope not
You really don’t see this?
noooo
Have you read this ? It might be the same case …
