I added panel like arch linux. after that this was happen. I removed extra panel & reset the settings… but still not solved
How did you ‘reset the settings’? Your xfce settings are stored in ‘~/.config/xfce/’. You could logout from xfce, then login in tty (crtl+alt+F2) and rename the ‘~/.config/xfce4/’-folder. (rename not delete for having a backup )
At next login to xfce, xfce should automatic load default settings-files from ‘/usr/share/xfce4/’ and create a new settings folder in ~/.config/.
For a less rowhammer methode you can search through the xfce config files in ‘~/.config/xfce4/’.
Sadly I cant tell you which config file exacly causes your problem.
I done rename folder and restart. themes are gone but screen problem still there.
Can you please post the output of this command before you restore your old settings?:
ls -lda ~/.config/*xfce*
So you can delete the new folder and rename back the old one to restore your themes.
Please that a look in xfce settings.
settings -> workspaces -> borders
If you set there borderpixels the windows will only expand to this border.
Thank you ! its Worked
