When I click on the Trash icon it opens up VLC
System:    Kernel: 5.10.83-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: GNOME 41.1
Machine:   Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
           serial: <superuser required>
           Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <superuser required>
           UEFI-[Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
Battery:   ID-1: BAT0 charge: 50.1 Wh (100.0%) condition: 50.1/60.0 Wh (83.6%) volts: 17.2
           min: 15.4 model: Celxpert L19C4PC0 status: Full
CPU:       Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
           arch: Zen 2 rev: 1 cache: L2: 4 MiB
           flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
           bogomips: 92666
           Speed: 2287 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz): 1: 3073
           2: 2828 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 4278 10: 4292 11: 1905
           12: 1905 13: 3403 14: 3215 15: 1397 16: 1398
Graphics:  Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo driver: nvidia
           v: 470.86 bus-ID: 01:00.0
           Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 05:00.0
           Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:2
           Display: x11 server: X.org 1.21.1.1 driver: loaded: amdgpu,nvidia
Audio:     Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
           Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
           bus-ID: 05:00.5
           Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus-ID: 05:00.6
           Sound Server-1: ALSA v: k5.10.83-1-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.40 running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
           driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0
           Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
           IF: wlp4s0 state: down mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
           Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Drives:    Local Storage: total: 476.94 GiB used: 275.17 GiB (57.7%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB
           temp: 40.9 C
Partition: ID-1: / size: 459.79 GiB used: 275.17 GiB (59.8%) fs: ext4 dev: /dev/nvme0n1p1
Swap:      ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: 53.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
Info:      Processes: 369 Uptime: 7m Memory: 15.07 GiB used: 3.07 GiB (20.4%) Init: systemd
           Compilers: gcc: 11.1.0 Packages: 1491 Client: gnome-shell v: 41.1 inxi: 3.3.09
When I click on the Trash icon it opens up VLC with a window with errors. I accidentally clicked a button to not show the errors again. But clicking on Trash still opens up VLC for some reason.
Hello @wildcard :wink:
Just change the default application on the context menu.
How? There is no context menu. Btw, I have Dash-To-Dock. This screenshot I’m trying to right click it and no context menu shows up.
Open nautilus, rightclick on a folder and change the application to open folders. Nautlius remembers the last application you open the folder with.
What’s Nautilus?
Nautilus is the default file explorer on gnome.
Ok. I right-click on Trash and there’s nothing to change.
No, that’s not what I mean… Trash is also a folder… please change it on any folder and it should work for every folder.
I’m confused. I have no idea what you’re talking about.
Look… on the sidebar are only shortcuts… folders are on the the right side.
Yeah and there are no Trash folders.
So, Trash on the sidebar is located at /home/$USER/.local/share/Trash. It is a shortcut to a folder. Rightclick on a folder, you see open and then open with another application (or something like that). There you can change the behavior.
Oh ok. Now I understand. Thanks!
maybe it;s a hint :upside_down_face:
