When I click on my sound option on task bar, whole of my desktop freezes
Hi dear manjaro lovers.
I’ve been using manjaro for two years and everything is done well; but when I click on my audio option on my task bar, whole of my desktop often freezes.
It especially happens when I click show additional options option and change to another port.
I’ll be very grateful if you solve my issue.
I forgot to write this information:
  Kernel: 6.1.53-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=db6a5684-f11a-49e3-9947-c42265718ac8 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Desktop System: Gigabyte product: N/A v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: Gigabyte model: P75-D3 v: x.x serial: <superuser required>
    UEFI: American Megatrends v: F11 date: 11/04/2013
  Info: model: Intel Core i3-2120 bits: 64 type: MT MCP arch: Sandy Bridge
    gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
    model-id: 0x2A (42) stepping: 7 microcode: 0x2F
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1596 high: 1598 min/max: 1600/3300 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1596 2: 1596 3: 1598
    4: 1597 bogomips: 26348
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GF119 [GeForce GT 610] vendor: Gigabyte driver: nvidia
    v: 390.157 alternate: nouveau,nvidia_drm non-free: series: 390.xx+
    status: legacy-active (EOL~late 2022) arch: Fermi code: GF1xx
    process: 40/28nm built: 2010-16 pcie: gen: 2 speed: 5 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:104a class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 84 s-size: 413x232mm (16.26x9.13")
    s-diag: 474mm (18.65")
  Monitor-1: VGA-0 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.14x9.06")
    diag: 470mm (18.51") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: kms_swrast x11:
    egl: 1.4 drv: nvidia inactive: wayland
  API: OpenGL v: 4.5 compat-v: 4.6.0 vendor: nvidia mesa v: 390.157
    glx-v: 1.4 direct-render: yes renderer: GeForce GT 610/PCIe/SSE2
    memory: 1.95 GiB
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Gigabyte 7
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  Device-2: NVIDIA GF119 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:0e08 class-ID: 0403
  API: ALSA v: k6.1.53-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.80 status: off with: pipewire-media-session
    status: off tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
    lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 931.51 GiB used: 271.98 GiB (29.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZRX-00D8PB0
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80 scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 271.98 GiB (29.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 53.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 201 Uptime: 50m wakeups: 0 Memory: total: 8 GiB
  available: 7.71 GiB used: 2.97 GiB (38.6%) Init: systemd v: 254
  Packages: 1631 pm: dpkg pkgs: 0 pm: pacman pkgs: 1630 libs: 435
  tools: pamac,yay pm: flatpak pkgs: 1 Shell: Zsh v: 5.9 default: Bash
  v: 5.1.16 running-in: yakuake inxi: 3.3.30
Post logs from when it happens. E.g. journalctl -S -10m -p4 --no-pager will show last 10 minutes.
Thanks for your replay; I don’t know why but it’s been fixed and how much I use it, it doesn’t freeze :slightly_smiling_face:.
