What's your favourite way to get desktop icons on Gnome?
As we all know Gnome removed desktop icons quite a while ago. Now there are several ways to get them back including but not limited to shell extensions, nautilus-legacy and more. Although that's pretty much all I know about. What method do you use?
If you use an option to have icons on your desktop - probably in the extension format - be sure to disable the extension before running updates.
In fact - that goes for all extensions. You don't want an incompatible extension to deadlock your system.
