I have an AMD Ryzen 5 5600g processor. Can I use stable-diffusion-intel?
If not, what is the simplest way for me to use stable diffusion?
Tell us your address and someone will come, install it, try it out, and tell you. (Or trust the description of the package.)
If you mean this:
It would seem that it works on AMD CPUs, since it’s part of the/in the Performance:
And that is in the AUR:
$ pamac search stable-diffusion
stable-diffusion-intel 20220906-4 AUR
So can be installed using:
pamac build stable-diffusion-intel
Hope this helps!
