I stumbled upon this problem when diagnosing another problem.
The original problems (ignore this for now)
- All HDDs spin up when opening or using Dolphin.
- All HDDs spin up every 15 minutes (traced this back to udisks2 & SMART)
The current problem:
SMART keeps re-enabling itself for all my HDD’s
I turned SMART off manually by using
# smartctl --smart=off /dev/sda
# smartctl --smart=off /dev/sdb
# smartctl --smart=off /dev/sdc
This changes “SMART support” to “Disabled”
smartctl --info /dev/sda | grep 'SMART support is:'
SMART support is: Available - device has SMART capability.
SMART support is: Disabled
After 5-10 minutes, I notice the drives spin up again and for whatever reason, SMART is re-enabled.
SMART support is: Enabled
Question:
Why is this happening? Which programs or settings could be on my system that re-enable SMART?
I want to turn this behavior off.
Thanks in advance for your time & help
Some logs or potentially useful info;
- File indexers are disabled
- Not using plasma-disks
- Checked background activities - nothing here related to HDD control
systemctl status smartd.service
â—‹ smartd.service - Self Monitoring and Reporting Technology (SMART) Daemon
Loaded: loaded (/usr/lib/systemd/system/smartd.service; disabled; preset: disabled)
Active: inactive (dead)
Docs: man:smartd(8)
man:smartd.conf(5)
grep -v '^#' /etc/smartd.conf
DEVICESCAN
cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=F9E6-F309 /boot/efi vfat umask=0077 0 2
UUID=7aea8ba8-3b20-4594-b889-00213203a1dc / ext4 defaults,noatime 0 1
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
UUID=60DC604EDC602110 /disk/12 ntfs-3g uid=1000,gid=1000,umask=0022 0 0
UUID=005407915407891C /disk/8 ntfs-3g uid=1000,gid=1000,umask=0022 0 0
UUID=081E27781E275DC6 /disk/4 ntfs-3g uid=1000,gid=1000,umask=0022 0 0
sudo dmesg | tail -n 200
[ 3737.373203] sd 4:0:0:0: [sda] Stopping disk
[ 3748.532305] sd 5:0:0:0: [sdb] Synchronizing SCSI cache
[ 3748.534022] sd 5:0:0:0: [sdb] Stopping disk
[ 3750.034123] sd 6:0:0:0: [sdc] Synchronizing SCSI cache
[ 3750.035529] sd 6:0:0:0: [sdc] Stopping disk
[ 4205.404804] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4205.406241] ata5.00: configured for UDMA/133
[ 4205.406351] ata5.00: Entering active power mode
[ 4213.973340] sd 4:0:0:0: [sda] Starting disk
[ 4213.973579] sd 4:0:0:0: [sda] Starting disk
[ 4213.977357] sd 4:0:0:0: [sda] Starting disk
[ 4214.477642] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4214.478197] ata6.00: supports DRM functions and may not be fully accessible
[ 4224.388658] ata6.00: supports DRM functions and may not be fully accessible
[ 4224.398010] ata6.00: configured for UDMA/133
[ 4224.400850] sd 5:0:0:0: [sdb] Starting disk
[ 4224.418851] sd 5:0:0:0: [sdb] Starting disk
[ 4224.420368] sd 5:0:0:0: [sdb] Starting disk
[ 4224.805736] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4233.753549] ata7.00: configured for UDMA/133
[ 4233.756274] sd 6:0:0:0: [sdc] Starting disk
[ 4233.778579] sd 6:0:0:0: [sdc] Starting disk
[ 4233.784496] sd 6:0:0:0: [sdc] Starting disk
[ 4234.158407] ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4234.160195] ata8.00: supports DRM functions and may not be fully accessible
[ 4234.160706] ata8.00: NCQ Send/Recv Log not supported
[ 4234.162295] ata8.00: supports DRM functions and may not be fully accessible
[ 4234.162641] ata8.00: NCQ Send/Recv Log not supported
[ 4234.163869] ata8.00: configured for UDMA/133
[ 4234.173998] ahci 0000:00:17.0: port does not support device sleep
[ 4234.174086] sd 7:0:0:0: [sdd] Starting disk
[ 4234.174219] sd 7:0:0:0: [sdd] Starting disk
[ 4234.179425] sd 7:0:0:0: [sdd] Starting disk
[ 4298.774912] sd 5:0:0:0: [sdb] Synchronizing SCSI cache
[ 4298.776713] sd 5:0:0:0: [sdb] Stopping disk
[ 4301.938702] sd 4:0:0:0: [sda] Synchronizing SCSI cache
[ 4301.939764] sd 4:0:0:0: [sda] Stopping disk
[ 4305.363219] sd 7:0:0:0: [sdd] Synchronizing SCSI cache
[ 4305.366634] sd 7:0:0:0: [sdd] Stopping disk
[ 4365.812559] sd 6:0:0:0: [sdc] Synchronizing SCSI cache
[ 4365.814089] sd 6:0:0:0: [sdc] Stopping disk
[ 4376.477165] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4384.983569] ata7.00: configured for UDMA/133
[ 4384.986240] sd 6:0:0:0: [sdc] Starting disk
[ 4385.001817] sd 6:0:0:0: [sdc] Starting disk
[ 4385.004930] sd 6:0:0:0: [sdc] Starting disk
[ 4459.725205] sd 6:0:0:0: [sdc] Synchronizing SCSI cache
[ 4459.726644] sd 6:0:0:0: [sdc] Stopping disk
[ 4755.479808] ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4755.481409] ata8.00: supports DRM functions and may not be fully accessible
[ 4755.481781] ata8.00: NCQ Send/Recv Log not supported
[ 4755.483147] ata8.00: supports DRM functions and may not be fully accessible
[ 4755.483498] ata8.00: NCQ Send/Recv Log not supported
[ 4755.484713] ata8.00: configured for UDMA/133
[ 4755.494841] ahci 0000:00:17.0: port does not support device sleep
[ 4755.494965] sd 7:0:0:0: [sdd] Starting disk
[ 4755.495108] sd 7:0:0:0: [sdd] Starting disk
[ 4755.496456] sd 7:0:0:0: [sdd] Starting disk
[ 4756.269857] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4756.271359] ata5.00: configured for UDMA/133
[ 4756.271478] ata5.00: Entering active power mode
[ 4764.917346] sd 4:0:0:0: [sda] Starting disk
[ 4764.917473] sd 4:0:0:0: [sda] Starting disk
[ 4764.919503] sd 4:0:0:0: [sda] Starting disk
[ 4765.463473] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4765.464230] ata6.00: supports DRM functions and may not be fully accessible
[ 4775.483837] ata6.00: supports DRM functions and may not be fully accessible
[ 4775.492289] ata6.00: configured for UDMA/133
[ 4775.495051] sd 5:0:0:0: [sdb] Starting disk
[ 4775.506827] sd 5:0:0:0: [sdb] Starting disk
[ 4775.513546] sd 5:0:0:0: [sdb] Starting disk
[ 4776.015197] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4785.035400] ata7.00: configured for UDMA/133
[ 4785.038145] sd 6:0:0:0: [sdc] Starting disk
[ 4785.053209] sd 6:0:0:0: [sdc] Starting disk
[ 4785.055668] sd 6:0:0:0: [sdc] Starting disk
[ 4877.365923] sd 7:0:0:0: [sdd] Synchronizing SCSI cache
[ 4877.369588] sd 7:0:0:0: [sdd] Stopping disk
[ 4877.929234] sd 6:0:0:0: [sdc] Synchronizing SCSI cache
[ 4877.930736] sd 6:0:0:0: [sdc] Stopping disk
[ 4893.621957] sd 4:0:0:0: [sda] Synchronizing SCSI cache
[ 4893.623123] sd 4:0:0:0: [sda] Stopping disk
[ 4895.110856] sd 5:0:0:0: [sdb] Synchronizing SCSI cache
[ 4895.112638] sd 5:0:0:0: [sdb] Stopping disk
[ 5405.411897] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 5405.414106] ata5.00: configured for UDMA/133
[ 5405.414228] ata5.00: Entering active power mode
[ 5413.975727] sd 4:0:0:0: [sda] Starting disk
[ 5413.976017] sd 4:0:0:0: [sda] Starting disk
[ 5413.977537] sd 4:0:0:0: [sda] Starting disk
[ 5414.475885] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 5414.476540] ata6.00: supports DRM functions and may not be fully accessible
[ 5424.403618] ata6.00: supports DRM functions and may not be fully accessible
[ 5424.412102] ata6.00: configured for UDMA/133
[ 5424.414892] sd 5:0:0:0: [sdb] Starting disk
[ 5424.435420] sd 5:0:0:0: [sdb] Starting disk
[ 5424.437415] sd 5:0:0:0: [sdb] Starting disk
[ 5424.819719] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 5433.808593] ata7.00: configured for UDMA/133
[ 5433.811281] sd 6:0:0:0: [sdc] Starting disk
[ 5433.825700] sd 6:0:0:0: [sdc] Starting disk
[ 5433.828573] sd 6:0:0:0: [sdc] Starting disk
[ 5434.171106] ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 5434.172838] ata8.00: supports DRM functions and may not be fully accessible
[ 5434.173246] ata8.00: NCQ Send/Recv Log not supported
[ 5434.174914] ata8.00: supports DRM functions and may not be fully accessible
[ 5434.175259] ata8.00: NCQ Send/Recv Log not supported
[ 5434.176471] ata8.00: configured for UDMA/133
[ 5434.186581] ahci 0000:00:17.0: port does not support device sleep
[ 5434.186653] sd 7:0:0:0: [sdd] Starting disk
[ 5434.186778] sd 7:0:0:0: [sdd] Starting disk
[ 5434.193433] sd 7:0:0:0: [sdd] Starting disk
[ 5488.976617] sd 4:0:0:0: [sda] Synchronizing SCSI cache
[ 5488.977833] sd 4:0:0:0: [sda] Stopping disk
[ 5499.426764] sd 5:0:0:0: [sdb] Synchronizing SCSI cache
[ 5499.428940] sd 5:0:0:0: [sdb] Stopping disk
[ 5505.368456] sd 6:0:0:0: [sdc] Synchronizing SCSI cache
[ 5505.369926] sd 6:0:0:0: [sdc] Stopping disk
[ 5508.982866] sd 7:0:0:0: [sdd] Synchronizing SCSI cache
[ 5508.986301] sd 7:0:0:0: [sdd] Stopping disk
[ 5654.431569] HDR SB:01 1a 02 00 a9 86 52 3b 1d 2f 9e 8b 6b 1c a3 0b
[ 5654.431582] HDR SB:3a 3d 47 40 f8 00 00 00 f8 00 f8 00 00 00 00 00
[ 5654.432184] HDR SB:01 1a 02 00 a9 86 52 3b 1d 2f 9e 8b 6b 1c a3 0b
[ 5654.432190] HDR SB:3a 3d 47 40 f8 00 00 00 f8 00 f8 00 00 00 00 00
[ 5654.436801] HDR SB:01 1a 02 00 a9 86 52 3b 1d 2f 9e 8b 6b 1c a3 0b
[ 5654.436813] HDR SB:3a 3d 47 40 f8 00 00 00 f8 00 f8 00 00 00 00 00
[ 5660.344428] HDR SB:01 1a 02 00 a9 86 52 3b 1d 2f 9e 8b 6b 1c a3 0b
[ 5660.344445] HDR SB:3a 3d 47 40 f8 00 00 00 f8 00 f8 00 00 00 00 00
[ 5984.484571] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 5993.488189] ata7.00: configured for UDMA/133
[ 5993.490968] sd 6:0:0:0: [sdc] Starting disk
[ 5993.506425] sd 6:0:0:0: [sdc] Starting disk
[ 5993.507946] sd 6:0:0:0: [sdc] Starting disk
[ 6005.389390] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6005.391206] ata5.00: configured for UDMA/133
[ 6005.391319] ata5.00: Entering active power mode
[ 6013.937127] sd 4:0:0:0: [sda] Starting disk
[ 6013.937325] sd 4:0:0:0: [sda] Starting disk
[ 6013.942059] sd 4:0:0:0: [sda] Starting disk
[ 6014.372763] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6014.373220] ata6.00: supports DRM functions and may not be fully accessible
[ 6024.335648] ata6.00: supports DRM functions and may not be fully accessible
[ 6024.344433] ata6.00: configured for UDMA/133
[ 6024.347219] sd 5:0:0:0: [sdb] Starting disk
[ 6024.368857] sd 5:0:0:0: [sdb] Starting disk
[ 6024.373235] sd 5:0:0:0: [sdb] Starting disk
[ 6024.733529] ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6024.735255] ata8.00: supports DRM functions and may not be fully accessible
[ 6024.735798] ata8.00: NCQ Send/Recv Log not supported
[ 6024.737286] ata8.00: supports DRM functions and may not be fully accessible
[ 6024.737631] ata8.00: NCQ Send/Recv Log not supported
[ 6024.738869] ata8.00: configured for UDMA/133
[ 6024.748983] ahci 0000:00:17.0: port does not support device sleep
[ 6024.749109] sd 7:0:0:0: [sdd] Starting disk
[ 6024.749299] sd 7:0:0:0: [sdd] Starting disk
[ 6024.754161] sd 7:0:0:0: [sdd] Starting disk
[ 6097.465742] sd 6:0:0:0: [sdc] Synchronizing SCSI cache
[ 6097.467288] sd 6:0:0:0: [sdc] Stopping disk
[ 6099.182359] sd 5:0:0:0: [sdb] Synchronizing SCSI cache
[ 6099.182392] sd 7:0:0:0: [sdd] Synchronizing SCSI cache
[ 6099.185902] sd 7:0:0:0: [sdd] Stopping disk
[ 6099.186983] sd 5:0:0:0: [sdb] Stopping disk
[ 6105.371248] sd 4:0:0:0: [sda] Synchronizing SCSI cache
[ 6105.372453] sd 4:0:0:0: [sda] Stopping disk
[ 6605.344165] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6605.345987] ata5.00: configured for UDMA/133
[ 6605.346107] ata5.00: Entering active power mode
[ 6613.893671] sd 4:0:0:0: [sda] Starting disk
[ 6613.893881] sd 4:0:0:0: [sda] Starting disk
[ 6613.898876] sd 4:0:0:0: [sda] Starting disk
[ 6614.343943] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6614.344523] ata6.00: supports DRM functions and may not be fully accessible
[ 6624.238330] ata6.00: supports DRM functions and may not be fully accessible
[ 6624.246819] ata6.00: configured for UDMA/133
[ 6624.249586] sd 5:0:0:0: [sdb] Starting disk
[ 6624.266347] sd 5:0:0:0: [sdb] Starting disk
[ 6624.267880] sd 5:0:0:0: [sdb] Starting disk
[ 6624.613183] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6633.607888] ata7.00: configured for UDMA/133
[ 6633.610539] sd 6:0:0:0: [sdc] Starting disk
[ 6633.625915] sd 6:0:0:0: [sdc] Starting disk
[ 6633.632912] sd 6:0:0:0: [sdc] Starting disk
[ 6633.966726] ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6633.968344] ata8.00: supports DRM functions and may not be fully accessible
[ 6633.968731] ata8.00: NCQ Send/Recv Log not supported
[ 6633.970124] ata8.00: supports DRM functions and may not be fully accessible
[ 6633.970443] ata8.00: NCQ Send/Recv Log not supported
[ 6633.971626] ata8.00: configured for UDMA/133
[ 6633.981736] ahci 0000:00:17.0: port does not support device sleep
[ 6633.981794] sd 7:0:0:0: [sdd] Starting disk
[ 6633.982331] sd 7:0:0:0: [sdd] Starting disk
[ 6633.982905] sd 7:0:0:0: [sdd] Starting disk
[ 6685.501900] sd 4:0:0:0: [sda] Synchronizing SCSI cache
[ 6685.503115] sd 4:0:0:0: [sda] Stopping disk
[ 6699.266144] sd 5:0:0:0: [sdb] Synchronizing SCSI cache
[ 6699.268128] sd 5:0:0:0: [sdb] Stopping disk
[ 6708.626168] sd 6:0:0:0: [sdc] Synchronizing SCSI cache
[ 6708.627599] sd 6:0:0:0: [sdc] Stopping disk
[ 6708.807077] sd 7:0:0:0: [sdd] Synchronizing SCSI cache
[ 6708.810652] sd 7:0:0:0: [sdd] Stopping disk
