So now that i removed SDDM and moved to plasma-login-manager i noticed that xorg was missing from the processes.
So does this mean that parts of xorg could be entirely removed to have Wayland and Xwayland only system? Also if yes then what packages exactly?
Ill write a list here that what X11 packages i have: xorg-fonts-encodings, xorg-mkfontscale, xorg-server, xorg-server-common, xorg-setxkbmap, xorg-twm, xorg-xauth, xorg-xdpyinfo, xorg-xinit, xorg-xkbcomp, xorg-xkill, xorg-xmessage, xorg-xmodmap, xorg-xprop, xorg-xrandr, xorg-xrdb and xorg-xset.
And of course i have xorg-xwayland package, but that i don’t want to remove.
Would be really neat to kick out X11 almost entirely finally.
Only x processes that i see running is xsettingsd and xembedsniproxy along with of course xwayland.
Packages that i could uninstall with a command were: sudo pacman -R xorg-mkfontscale xorg-server xorg-twm xorg-xauth xorg-xinit xorg-xkill xorg-xmodmap xorg-xrandr xorg-xset.
I’ll suggest leaving the ones which still have dependencies and review them again after subsequent bundled updates; you may find the number will reduce over time.
You might also be able to remove some xf86- packages. I was just able to remove all of the above packages (minus xorg-xrandr, which wasn’t installed) as well as these 2 packages:
pamac info xf86-video-ati xf86-input-libinput | grep -E 'Name|Description'
Description : X.org ati video driver
Description : Generic input driver for the X.Org server based on
If I encounter any issues (I don’t really expect any), I’ll let you know.
So there’s not much xorg remaining on my Plasma Wayland system:
pamac search -i xorg
xorgproto 2025.1-1 extra
combined X.Org X11 Protocol headers
xorg-xwayland 24.1.9-1 extra
run X clients under wayland
xorg-xrdb 1.2.2-2 extra
X server resource database utility
xorg-xprop 1.2.8-1 extra
Property displayer for X
xorg-xmessage 1.0.7-1 extra
Display a message or query in a window
xorg-xkbcomp 1.5.0-1 extra
X Keyboard description compiler
xorg-xdpyinfo 1.4.0-1 extra
Display information utility for X
xorg-setxkbmap 1.3.4-2 extra
Set the keyboard using the X Keyboard Extension
xorg-server-common 21.1.21-1 extra
Xorg server common files
xorg-fonts-encodings 1.1.0-1 extra
X.org font encoding files
