when updating the system I’m getting this warning message:
WARNING: '/usr/lib/perl5/5.32' contains data from at least 1 packages which will NOT be used by the installed perl interpreter.
-> Run the following command to get a list of affected packages: pacman -Qqo '/usr/lib/perl5/5.32'
Then I run these commands:
$ pacman -Qqo '/usr/lib/perl5/5.32'
perl-goo-canvas
$ sudo pacman -Rsn perl-goo-canvas
checking dependencies...
Packages (6) cairo-perl-1.108-1 glib-perl-1.329.3-2 goocanvas1-1.0.0-5
gtk2-perl-1.24993-3 pango-perl-1.227-14
perl-goo-canvas-0.06-11
Total Removed Size: 7.30 MiB
:: Do you want to remove these packages? [Y/n] n
When deleting those packages I don’t know how my system will be affected. What should I do?
