Hi!
How the title says, i’ve a little problem with my computer. I don’t know why, but when i restart Manjaro, my SSD drive has gone out and dissapear. I will to do a shutdown and again power-on, and my hard disk shows in the BIOS. I will try to search in Arch forums, similar issues and try to change the “cold reboot” to a “warm reboot”. In Windows, I see how do that. It shutdown the computer and some seconds later it power on again. But with Manjaro, I don’t know why, it does.
I’m using a PCIE USB3.0/SATA6, due to my chipset board, a SATA3, and the benchmarks says all. SATA6 is working fine and smoothly. (And the 450-500 MB’s…Read/Write)
I love Manjaro, I’ve using a lot of years Ubuntu in my laptop and change to Pop/OS, and in my personal computer i will try a new challenge. Arch vitamined. To the problem…
Kernel: 5.8.1-3-MANJARO x86_64 bits: 64 compiler: N/A Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel
wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: P5Q DELUXE v: Rev 1.xx serial: <filter> BIOS: American Megatrends v: 2301
date: 07/10/2009
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard PID:005c serial: N/A charge: 5% (should be ignored)
rechargeable: yes status: Discharging
CPU: Topology: Quad Core model: Intel Xeon X5470 bits: 64 type: MCP arch: Penryn rev: A L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 26730
Speed: 2025 MHz min/max: 2003/3336 MHz Core speeds (MHz): 1: 2795 2: 2308 3: 2003 4: 2004
Graphics: Device-1: NVIDIA GF114 [GeForce GTX 560 Ti] vendor: ASUSTeK driver: nvidia v: 390.132 bus ID: 01:00.0
chip ID: 10de:1200
Display: x11 server: X.Org 1.20.8 driver: nvidia resolution: 1: 1920x1080~60Hz 2: 1080x1920~60Hz s-dpi: 96
OpenGL: renderer: GeForce GTX 560 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 390.132 direct render: Yes
Audio: Device-1: Intel 82801JI HD Audio vendor: ASUSTeK P5Q Deluxe driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:3a3e
Device-2: NVIDIA GF114 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 10de:0e0c
Device-3: Creative Xmod type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 10-2:2 chip ID: 041e:30d0
Sound Server: ALSA v: k5.8.1-3-MANJARO
Network: Device-1: Marvell 88E8056 PCI-E Gigabit Ethernet vendor: ASUSTeK driver: sky2 v: 1.30 port: c800 bus ID: 08:00.0
chip ID: 11ab:4364
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Marvell 88E8001 Gigabit Ethernet vendor: ASUSTeK driver: skge v: 1.14 port: e800 bus ID: 0b:02.0
chip ID: 11ab:4320
IF: enp11s2 state: down mac: <filter>
Drives: Local Storage: total: 2.26 TiB used: 1.66 TiB (73.4%)
ID-1: /dev/sda vendor: Seagate model: ST2000DX001-1NS164 size: 1.82 TiB speed: 6.0 Gb/s rotation: 7200 rpm
serial: <filter> rev: CC41 scheme: MBR
ID-2: /dev/sdb vendor: Intel model: SSDSC2KW480H6 size: 447.13 GiB speed: 6.0 Gb/s serial: <filter> rev: 042C
scheme: MBR
Partition: ID-1: / size: 125.97 GiB used: 81.47 GiB (64.7%) fs: ext4 dev: /dev/sdb6
ID-2: /boot size: 998.0 MiB used: 118.9 MiB (11.9%) fs: vfat dev: /dev/sdb1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 52.0 C mobo: N/A gpu: nvidia temp: 51 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Info: Processes: 218 Uptime: 1d 15h 19m Memory: 7.77 GiB used: 3.81 GiB (49.1%) Init: systemd v: 245 Compilers:
gcc: 10.1.0 Packages: 1322 pacman: 1317 snap: 5 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
I’ve checked the Marvell issues, but those are in 3.xx kernels… Also i’ve tried LTS and 5.7 kernel. And both does the same. The computer works like a charm but i’ve a headache with this.
Pd. It’s strange, I have two disks connected. And only dissapear the SSD where is located the OS.
