I used bluetooth audio (bluetooth earphone) often, but after update it successfully connect and recognized but no sound. Have tried restarting pc as well.
Normally it works but sometimes I have to systemctl restart bluetooth
otherwise it will be unable to connect.
The earphone is not broken, it still worked on my phone.
Actually I’m not sure if it’s this update or previous one but it should not be too far.
As I wrote this post, I have not attempted to fix this issue.
Hardware
Earphone: Aukey EP-T25
Bluetooth adapter: VENTION USB Bluetooth 5.0 Dongle Adapter,
Version: Bluetooth 5.0+BR/EDR
Chip: RTL8761B
Logs
systemctl status bluetooth
bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Wed 2022-11-02 00:40:02 WIB; 2min 22s ago
Docs: man:bluetoothd(8)
Main PID: 3242 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 19078)
Memory: 1.7M
CPU: 40ms
CGroup: /system.slice/bluetooth.service
└─3242 /usr/lib/bluetooth/bluetoothd
Nov 02 00:40:02 Everlight-ManjaroRE1 bluetoothd[3242]: Endpoint registered: sender=:1.45 path=/MediaEndpoint/A2DPSource/aptx
Nov 02 00:40:02 Everlight-ManjaroRE1 bluetoothd[3242]: Endpoint registered: sender=:1.45 path=/MediaEndpoint/A2DPSink/sbc
Nov 02 00:40:02 Everlight-ManjaroRE1 bluetoothd[3242]: Endpoint registered: sender=:1.45 path=/MediaEndpoint/A2DPSource/sbc
Nov 02 00:40:02 Everlight-ManjaroRE1 bluetoothd[3242]: Endpoint registered: sender=:1.45 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Nov 02 00:40:02 Everlight-ManjaroRE1 bluetoothd[3242]: Endpoint registered: sender=:1.45 path=/MediaEndpoint/A2DPSource/sbc_xq_453
Nov 02 00:40:02 Everlight-ManjaroRE1 bluetoothd[3242]: Endpoint registered: sender=:1.45 path=/MediaEndpoint/A2DPSink/sbc_xq_512
Nov 02 00:40:02 Everlight-ManjaroRE1 bluetoothd[3242]: Endpoint registered: sender=:1.45 path=/MediaEndpoint/A2DPSource/sbc_xq_512
Nov 02 00:40:02 Everlight-ManjaroRE1 bluetoothd[3242]: Endpoint registered: sender=:1.45 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Nov 02 00:40:02 Everlight-ManjaroRE1 bluetoothd[3242]: Endpoint registered: sender=:1.45 path=/MediaEndpoint/A2DPSource/sbc_xq_552
Nov 02 00:40:16 Everlight-ManjaroRE1 bluetoothd[3242]: /org/bluez/hci0/dev_41_42_96_46_9B_8B/sep1/fd0: fd(41) ready
I forgot which inxi command to run. There are many in my zsh history.
inxi --admin --verbosity=7 --filter --no-host --width ✔
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=1a2e73bb-4d24-4a29-bb7a-9feb4e4ce13f rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 info: plank wm: gnome-shell
dm: GDM v: 42.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: B450M-HDV R4.0 serial: <superuser required>
UEFI: American Megatrends v: P4.50 date: 03/12/2021
RAM: total: 15.55 GiB used: 3.95 GiB (25.4%)
Info: model: AMD Ryzen 5 3500 bits: 64 type: MCP arch: Zen 2 gen: 3 level: v3
note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 2467 high: 3515 min/max: 2200/4120 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2909 2: 2053
3: 2119 4: 2056 5: 3515 6: 2152 bogomips: 43222
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU117 [GeForce GTX 1650] driver: nvidia v: 520.56.06
alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Turing code: TUxxx process: TSMC 12nm
built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 09:00.0 chip-ID: 10de:1f82 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x2160 s-size: <missing: xdpyinfo>
Monitor-1: DP-1 pos: primary,top res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: HDMI-0 pos: bottom res: 1920x1080 hz: 60 dpi: 166
size: 294x166mm (11.57x6.54") diag: 338mm (13.29") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce GTX
1650/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 1-8:2 pcie:
chip-ID: 0c76:126e gen: 3 speed: 8 GT/s class-ID: 0300 lanes: 16
bus-ID: 09:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-9:3 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Local Storage: total: 2.96 TiB used: 1.27 TiB (43.0%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 3B2QEXM7 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000VX008-2E3164
type: HDD rpm: 5900 serial: <filter> rev: CV12 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: V-Gen model: 01SM21NT256MT
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 5A0 scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 97.66 GiB (100.00%) used: 33.7 GiB (34.5%)
fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 1a2e73bb-4d24-4a29-bb7a-9feb4e4ce13f
ID-2: /boot/efi raw-size: 1000 MiB size: 996 MiB (99.60%)
used: 26.5 MiB (2.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: D4F8-5870
ID-3: /home raw-size: 390.62 GiB size: 383.43 GiB (98.16%)
used: 271.44 GiB (70.8%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: home uuid: 3b3e44b5-a833-4e09-b668-250413d14da3
ID-4: /mnt/warehouse raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 997.81 GiB (53.6%) fs: ntfs dev: /dev/sda2 maj-min: 8:2
label: Warehouse uuid: 9C5EDB7B5EDB4CA0
ID-5: /var/cache raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
used: 33.7 GiB (34.5%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 1a2e73bb-4d24-4a29-bb7a-9feb4e4ce13f
ID-6: /var/log raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
ID-1: swap-1 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: a744f76f-4318-41b8-8117-a8299568048d
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 97.14 GiB fs: ntfs label: N/A
uuid: 56B4F6A3B4F684B1
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 516 MiB fs: ntfs label: N/A
uuid: 50642D1A642D03F6
ID-4: /dev/nvme0n1p8 maj-min: 259:8 size: 332.88 GiB fs: ntfs
label: CrossApps uuid: 424EFD4D4EFD3A6D
ID-5: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-6: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
ID-7: /dev/sdb2 maj-min: 8:18 size: 238.46 GiB fs: ntfs label: N/A
uuid: A008D09008D06736
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-8:2 info: JMTek LLC. USB PnP Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0c76:126e class-ID: 0300
Device-2: 1-9:3 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 0bda:8771
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 3-4:2 info: Alcor Micro USB Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 058f:6254 class-ID: 0900
Hub-5: 3-4.4:3 info: Alcor Micro USB Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-4.4.2:4 info: Wacom One Pen Display 13 type: HID
driver: usbhid,wacom interfaces: 2 rev: 2.0 speed: 12 Mb/s chip-ID: 056a:03a6
class-ID: 0300 serial: <filter>
Device-2: 3-4.4.3:5 info: Holtek USB-HID Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04d9:0344 class-ID: 0300
Device-3: 3-4.4.4:6 info: Logitech G502 SE HERO Gaming Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c08b class-ID: 0300
serial: <filter>
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 51.4 C mobo: N/A gpu: nvidia temp: 54 C
Processes: 307 Uptime: 14m wakeups: 0 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1589 libs: 463 tools: gnome-software,pamac,yay pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.23
