I tried to install a game that requiered libssl.so.1.0.0. Searching in pamac-manager for libssl did show three packages, openssl, lib32-openssl and openssl-1.1.
It did however not list openssl-1.0, which included the needed file.
Not even searching for libssl* or libssl.so.1.0.0 does show the right package. (openssl-1.0)
I think there is a problem with the pamac-manager that should be fixed. It should at least show a package if I search for a filename that is included in that package.
I donāt think pamac is that advanced. Use pacman as follows:
pacman -Qo path to file for example:
pacman -Qo /usr/lib/libstdc++.so.6
/usr/lib/libstdc++.so.6 is owned by gcc-libs 12.1.0-1
And while at it, if you search for a favourite ice-cream it should output nearby store which has it?
That works if you already have package installed.
Otherwise you need to use -Fy
(to update file database) and -Fx filename
thank you.
Jokes aside, is there a way for him to search for a package that provides a file without having said package installedm that actually provides that file?
eg. Search for a file to be provided by a not-yet installed package.
Yes, I just mentioned it in previous comment.
Iām not using pamac
, so I donāt know what GUI searches for. But I can google āman pamacā, click on a page, do a ctrl+f and search for word āfileā in under a minute:
pamac search [options] <package(s)>
Search for packages or files, multiple search terms can be specified
And after reading this, I still donāt know what does it do in terminal. (I guess OP is right, it should find files too. But why does it only say <package(s)>
Nevermind, you have to actually read whatās in the pageā¦
You can use -f
to find what package owns a file, aka pacman -Qo
. So useless in this case.
I said I was searching for the name of the file, not the package. Of yourse searching for openssl will liste openssl-1.0. But searching for libssl.so does not list openssl-1.0
Aha ok, just to make that part clear for the topic
pacman
to the rescue:
$ sudo pacman -Fy libssl.so.1.0.0
core is up to date
extra is up to date
community is up to date
multilib is up to date
core/openssl-1.0 1.0.2.u-1
usr/lib/libssl.so.1.0.0
community/teamspeak3 3.5.6-3
opt/teamspeak3/libssl.so.1.0.0
