I recently installed Apex Legends(Proton-GE) on my laptop with AMD Ryzen 4700U APU. But I am getting a terrible performance. These are the tweaks I’ve done with the launcher
gamemoderun mangohud WINE_FULLSCREEN_FSR=1 WINE_FULLSCREEN_FSR_STRENGTH=8 %command% -dev -preload -high -novid -fullscreen
I am getting a frame rate below 20 with my current tweaks. This is my system specifications
Kernel: 5.17.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=fb08653b-525e-4768-90b2-4d0986419e80 rw quiet splash apparmor=1
nouveau.modeset=0 security=apparmor
resume=UUID=564940a7-1b64-4ba8-bd4a-cef4c3c3a4f3 udev.log_priority=3
bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
nvme_core.default_ps_max_latency_us=5500
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_wayland vt: 2
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X421IAY_M413IA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X421IAY v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X421IAY.305 date: 07/31/2020
ID-1: BAT0 charge: 37.1 Wh (100.0%) condition: 37.1/42.1 Wh (88.3%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 162
Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1410 high: 1504 min/max: 1400/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1504 2: 1397
3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 bogomips: 31958
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-3:4 chip-ID: 13d3:56a8 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
alternate: fbdev,vesa gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.17.0-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.8 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.17.0-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: no
Sound Server-5: PipeWire v: 0.3.49 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2:3
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 535.66 GiB used: 278.57 GiB (52.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 type: SSD serial: <filter> rev: 004C temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: HP model: v232w
size: 28.91 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 0009 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB model: Multiple Card Reader
size: 29.81 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 349.67 GiB size: 343.18 GiB (98.14%)
used: 277.46 GiB (80.9%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 350 MiB size: 349.3 MiB (99.80%)
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
ID-1: swap-1 type: partition size: 7.81 GiB used: 1.1 GiB (14.1%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 66.0 C mobo: N/A gpu: amdgpu temp: 47.0 C
Fan Speeds (RPM): cpu: 2600
Processes: 305 Uptime: 2h 2m wakeups: 8355 Memory: 7.25 GiB
used: 3.7 GiB (51.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1819 pacman: 1801 lib: 534 flatpak: 8
snap: 10 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.15
Is there anything to do with my os to get better performance? Or am I getting the performance supposed to get with my hardware?
