What Kernel should I Run Lutris on. Because having trouble running any thing
Running 5.8.13-2-MANJARO
this is the kernel Im Running
Can you provide a little more information please? What problems are you having? Are games failing to launch, are they low fps, are they native steam or proton?
The best thing about lutris is if you select the terminal icon while launching youā€™ll get a log of what is happening
and my steam Libreary is also messed up , when i try to launch a game nothing happens
if I would reinstall everything , do i need to install steam ? or Just Installing lutris is enough ?
thank u
Which games and are they native linux or proton? If they are proton are they games that work well on proton? Unfortunately there are some games that just donā€™t work on linux. If they are not native linux check the proton database to see what support they have
thank u for ur help
Can u just tell me in what order should i install what ?
i want to reinstall steam and lutris
how do i go about that after a clean uninstall ?
can u please tell me ?
thanks
Before anyone can help we need to know what errors you are getting and which games you are trying to play, it could be something as simple as a missing lib. What does the lutris log say when you try and launch a game
Your issues most likely have nothing to do with kernel. Itā€™s possible you have incorrect GPU setting. Do you have hybrid GPUs?
Also, you may miss some crucial packages. We need a lot of info from you to figure out what is wrong and then help you fix it. At the moment we know nothing, so our help will also be none existent.
At least, show us output of those commands (format it properly):
inxi -Fxxx0
mhwd -li
Then open Steam or Lutris through terminal, launch the game. Copy the output and paste here. It will probably show a hint what is wrong.
~ >>> inxi -Fxxx0
  Host: tempo-tempo Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
  Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
  Distro: Manjaro Linux
  Type: Desktop Mobo: Micro-Star model: MPG Z490 GAMING EDGE WIFI (MS-7C79)
  v: 1.0 serial: <superuser/root required> UEFI: American Megatrends v: 1.10
  date: 05/21/2020
  Topology: 8-Core model: Intel Core i7-10700K bits: 64 type: MT MCP
  arch: N/A L2 cache: 16.0 MiB
  bogomips: 121639
  Speed: 1800 MHz min/max: 800/5100 MHz Core speeds (MHz): 1: 1800 2: 1800
  3: 1800 4: 1801 5: 1801 6: 1800 7: 1801 8: 1801 9: 1800 10: 1800 11: 1800
  12: 1800 13: 1800 14: 1800 15: 1800 16: 1801
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
  vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 01:00.0
  chip ID: 1002:67df
  Display: x11 server: X.org 1.20.9 compositor: gnome-shell
  driver: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
  resolution: <xdpyinfo missing>
  OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.38.0
  5.8.11-1-MANJARO LLVM 10.0.1)
  v: 4.6 Mesa 20.1.8 direct render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:06c8
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
  vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 01:00.1
  chip ID: 1002:aaf0
  Device-3: Microsoft LifeCam HD-3000 type: USB
  driver: snd-usb-audio,uvcvideo bus ID: 1-3:3 chip ID: 045e:0810
  Device-4: Corsair CORSAIR VOID ELITE Wireless Gaming Dongle type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-7:5 chip ID: 1b1c:0a55
  Sound Server: ALSA v: k5.8.11-1-MANJARO
  Device-1: Intel Wireless-AC 9462/9560 driver: iwlwifi v: kernel
  bus ID: 00:14.3 chip ID: 8086:06f0
  IF: wlo1 state: up mac: 54:8d:5a:cf:90:6d
  Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: N/A
  port: 3000 bus ID: 04:00.0 chip ID: 10ec:8125
  Local Storage: total: 2.96 TiB used: 75.01 GiB (2.5%)
  ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS250G2B0C-00PXH0
  size: 232.89 GiB speed: 31.6 Gb/s lanes: 4 serial: 202224805724
  rev: 211070WD scheme: GPT
  ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO Plus 250GB
  size: 232.89 GiB speed: 31.6 Gb/s lanes: 4 serial: S4EUNJ0N400962W
  rev: 2B2QEXM7 scheme: GPT
  ID-3: /dev/sda vendor: Toshiba model: HDWD130 size: 2.73 TiB
  speed: 6.0 Gb/s rotation: 7200 rpm serial: 403TJDBAS rev: ACF0 scheme: GPT
  ID-1: / size: 227.94 GiB used: 75.01 GiB (32.9%) fs: ext4 dev: /dev/dm-0
  System Temperatures: cpu: 47.0 C mobo: N/A gpu: amdgpu temp: 35 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1214
  Processes: 409 Uptime: 2h 06m Memory: 31.28 GiB used: 3.16 GiB (10.1%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1432 pacman: 1424
  snap: 8 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.05
No hybrid GPUs here, this makes the situation clearer.
You can launch any program through terminal, so you can open it and just type
steam
or
lutris
and hit enter. Terminal will spew a lot of lines. Try launching a game, if it crashes or results in error, copy all terminalā€™s output and paste it here.
I will be following this topic also, because i had Lutris operational while using ā€œanother distroā€, but am still unable to get it working on Manjaro alsoā€¦
(PS: Steam is working ok for me)
One thing to remember is that you wonā€™t be able to use the ā€œEpic-Gamesā€ launcher, and thus non of the games that you download using thatā€¦
What errors are you getting with lutris? Iā€™ve had no problems with it on manjaro
same, I didnā€™t know there was ā€˜launch from terminalā€™ button in Lutris - that would be super helpful for the issue I am havingā€¦I think. Am I right in understanding that he is using the drivers from AMD and not the free drivers? I had some issues with the drivers from AMD and switched to free ones.
Another question for @Fires, are you using ā€˜steam nativeā€™ or ā€˜steam-Manjaroā€™?
