Hi,
My desktop with Manjaro and Gnome 40 randomly disconnects from the wired network and then reconnects. As I work on this computer all day, every day, this is quite annoying, also because I am often connected with a VPN and every time it disconnects, it also breaks the tunnel.
Weirdly (or perhaps not) enough I had the same problem with my laptop connected to the same network: see Wired connection continously connects and disconnects
With my laptop I solved the problem by using a different kernel module: r8168 instead of r8169. I am doing the same with my desktop, but it does not work.
9:05:28 ⟩ sudo dmesg | grep r8168
[ 2.898331] r8168: loading out-of-tree module taints kernel.
[ 2.939386] r8168: module verification failed: signature and/or required key missing - tainting kernel
[ 2.942964] r8168 Gigabit Ethernet driver 8.049.02-NAPI loaded
[ 2.942983] r8168 0000:03:00.0: enabling device (0000 -> 0003)
[ 2.942991] r8168 0000:03:00.0: can't find IRQ for PCI INT A; please try using pci=biosirq
[ 2.959608] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 2.961639] r8168 Copyright (C) 2021 Realtek NIC software team <nicfae@realtek.com>
[ 3.060475] r8168 0000:03:00.0 enp3s0: renamed from eth0
[ 6.301645] r8168: enp3s0: link up
[ 3978.578097] r8168: enp3s0: link down
[ 3990.781175] r8168: enp3s0: link up
[ 4136.711160] r8168: enp3s0: link down
[ 4148.914286] r8168: enp3s0: link up
You can see the entries in dmesg where it says link down/link up, is when this happens.
I looked a bit around some time ago trying to solve this, and at a certain point I though it had to do with the promise (not really sure what that is), but right now I don’t remember where I found that info.
My inxi is
9:13:17 ⟩ inxi -Fxzc0
System: Kernel: 5.12.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: GNOME 40.3 Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Desktop Mobo: ASRock model: X300M-STX serial: <filter> UEFI: American Megatrends v: P1.40 date: 08/04/2020
Battery: Device-1: hidpp_battery_0 model: Logitech G603 Wireless Gaming Mouse charge: 100% (should be ignored)
status: Discharging
CPU: Info: 8-Core model: AMD Ryzen 7 PRO 4750G with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 rev: 1 cache:
L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 115039
Speed: 2994 MHz min/max: 1400/3600 MHz boost: enabled Core speeds (MHz): 1: 2994 2: 1380 3: 1391 4: 1346 5: 3041
6: 1339 7: 3019 8: 1330 9: 1377 10: 1353 11: 1397 12: 1397 13: 1671 14: 1372 15: 1512 16: 1397
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir driver: amdgpu v: kernel bus-ID: 04:00.0
Device-2: Logitech HD Webcam C525 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-2.2:5
Display: x11 server: X.org 1.20.13 driver: loaded: amdgpu,ati unloaded: modesetting resolution: <missing: xdpyinfo>
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel v: kernel bus-ID: 04:00.1
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 04:00.6
Device-3: Logitech HD Webcam C525 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-2.2:5
Sound Server-1: ALSA v: k5.12.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Network: Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel bus-ID: 02:00.0
IF: wlp2s0 state: down mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8168 v: 8.049.02-NAPI
port: f000 bus-ID: 03:00.0
IF-ID-1: vpn0 state: down mac: N/A
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2.1:4
Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Drives: Local Storage: total: 238.47 GiB used: 76.42 GiB (32.0%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: THNSN5256GPUK NVMe 256GB size: 238.47 GiB temp: 50.9 C
Partition: ID-1: / size: 237.97 GiB used: 76.42 GiB (32.1%) fs: btrfs dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 42.9 C mobo: N/A gpu: amdgpu temp: 32.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1151 fan-3: 0 fan-4: 0 fan-5: 0
Info: Processes: 397 Uptime: 1h 24m Memory: 13.62 GiB used: 4.73 GiB (34.8%) Init: systemd Compilers: gcc: 11.1.0
clang: 12.0.1 Packages: 1231 Shell: Zsh v: 5.8 inxi: 3.3.06
I should mention that I do not have access to the router as I live in a academic residence, where essentially I can either connect to the wifi (where I did not notice any problem with random disconnections/reconnections, however I have not tested it properly), or I can simply connect to the (only) ethernet socket available, which just works out of the box (besides this issue I am having with the random disconnections).
