What is the difference between buildiso
, buildiso -x
and buildiso -z
it says that:
-x Build images only
-z Generate iso only
What is the difference between build image
and generate iso
, Will it create some extra files if I do not add -x
/-z
Simple:
It generates the squash images. These images contains the root filesystem and therefore the software.
Something like a WIM Image on Windows.
This will create a bootable iso image with the previous created squash images.
So build a image means build a linux filesystem inside my conputer, and generate an ISO means to compress the linux filesystem to an ISO disk?
No exactly.
Build image means: create compressed and de-duplicated images of the virtual root filesystem, which I just created for the ISO.
Generate is means: Create a bootable ISO Image. (ISO Files are not compressed)
