I am trying to re-install Manjaro Gnome onto my PC to replace the massively unstable Deepin 20.2. I have tried a number of different USB sticks and get error messages every time. The message is either
Kernel panic- not syncing VFS unable to mount rootfs on unknown-block
or
can’t read superblock on /dev/loop3
or
wrong fs type, bad option, bad superblock on /dev/loop0
I have tried checking the disks with fsck but none of them seem to have a problem. I have tried creating the live image with dd, ventoy and Suse Imagewriter. Nothing helps. What is really strange is that when I use a stick with Ventoy installed and 3 different iso’s on it the only image that will boot and run is the Kubuntu one. I really don’t want to go back to using Ubuntu.
